Look very carefully, new stem has revealed an issue.
Wonky decal?
Hahahaha! Send them back!
I'd guess the painted lines were wonky rather than twisted bars?
What d'you press bro? 💪
Ahhhh! Which side do I line it up to!
More common than you think on bars that have separate alignment markers either side of the centreline. Pick the one you like best, and then be a dick to the other side. 😉
I only ever use one side anyway, problem is if the markings are on the p!ss maybe they're off centre as well.
Just checking, does anyone else tape a stick to their saddle and swing the bars 90° left n right to see if they're even, some bars can be out several millimetres, would you notice if your bar was 5mm higher on one side.
endomick - that not the bars, that's your frame twisted.
You need a new bike...
fadda, funny you should say that, I have a method for checking that to, an old uncut steerer crown assembly, I always check it lines up with a seatpost, I've actually sent a frame back when it didnt pass my inspection, headtube was like one minute past 12, shocking quality control.
Put the old stem back on - hth!
What makes you think your arms are the same length?
You just need to rotate the right side of the bar up a tad.
New bike !
Having broken my collar bone a few times, wonky bars would be perfect for my wonky shoulder. Can I have them? 😁
Build up your lefthand grip with layers of wafer thin ham until you are happy
Some carefully placed explosive charges will straighten them out.
https://twitter.com/MachinePix/status/1334559037157994496
Lol, has the potential to be another classic thread in the making.😁
More importantly, get that bloody Rubik's cube sorted.
Easton make brick archways too.
