....would like a 15-20mm longer TT? Don't want anything significantly heavier or less springy.
Slackline is (as far as I can work out from their unclear geometry info) pretty much the same length. Anything else? Custom probably not an option due to cost.
Larger framed Soul?
Already on a large.
The Prince Albert classic looks bang on - all gone, of course. Gah.
Sanderson Life/Breath
Solaris, obviously ๐
30-40mm wider bars will achieve the same feel and extra breathing room as 15-20mm in the top tube for a lot less expense! will also make the bike feel more stable and quicken the steering. Win-Win ๐
Unless running wide bars already I'd recommend trying davewalsh's suggestion - I had the same issue with my Hustler, it felt a bit short in top tube, already had 90mm stem and reverb meant no layback option on seatpost. Swapped from 685mm bars to 750mm and it solved the problem.
And/or 5-10mm longer stem?
Sometimes it is worth tweaking the controls to keep an otherwise bob on bike IMO...
For exactly that reason, I have a Solaris, bought 2nd had from here
The build up will start today - but most of the stuff I will use is still attached to my Soul in Germany!!
Obviously not the wheel or forks !!
The Soul was just too small - not sure why Si doesn't do XL
That might be it, y'know - I have narrower (Haven) bars on the Soul than other bikes (Havoc). Maybe go that route.
