What happens to the...
[Closed] What happens to the old dampers after a FIT Upgrade?
What do mojo/loco do with them?
Posted : 02/08/2012 4:14 pm
bin?
Posted : 02/08/2012 4:18 pm
There's no such thing as damper heaven?
Ask the customer if they want them back?
If not, perhaps a refurb then sell on?
Posted : 02/08/2012 4:20 pm
What I'm thinking is.
I have just got some 32 vanilla r's for a 456 winter bike but I like the rl on a hardtail.
FIT rlc upgrade
loco £150,
mojo £250+.
Second hand rl damper = ????
Posted : 02/08/2012 4:43 pm
 LoCo
You get them back if they've been replaced, bit cheeky to keep them isn't it, unless they're broken, in which case you can have them back or get a discount if any parts are re useable, we hate throwing stuff away if it will still be of use
Edit: don't you know the track cycling on ?! 😀
Posted : 02/08/2012 4:52 pm
Watching now Si 🙂 was stuck in traffic!
Go team GB
Posted in the Wanted section.
Posted : 02/08/2012 5:48 pm
I had a hell of a time finding a S/H Damper - I thought there would be millions of 'em -
I ended up machining a damper extension to get a longer a2c with the same travel (using some 29er stanchions - long story)
Posted : 02/08/2012 6:11 pm
Mojo give you the old damper back. Ive got mine sitting in a cupboard here
Posted : 02/08/2012 6:28 pm
Julians would you like to part with it ?
If its the right spec.
Posted : 02/08/2012 8:50 pm
I have a 130mm Terra Logic damper going spare if your interested, I upgraded to RLC. 😀
Posted : 02/08/2012 9:07 pm
Sorry, Im going to keep it as a spare.
Posted : 02/08/2012 9:25 pm
 edd
I've got a spare 140mm (travel) open bath R damper for a Fox 26" 32. I'll post it for £15 if anyone's interested.
Posted : 02/08/2012 9:30 pm
 Kuco
I had mine sent back with the forks.
Posted : 02/08/2012 9:31 pm
I would be after a 14 rl or rlc.
Posted : 03/08/2012 5:57 am
Mow much would people like for all these Dampers?
I have a set of lowers and uppers that could do with one.
Posted : 03/08/2012 8:20 am
I'm £55 posted for mine, I have just realised that the Air side controls the travel not the damper DOH!
My TTL cart will do 120 - 140mm.
Posted : 03/08/2012 9:58 am
Sonofapitch,
You can swap the top caps out to give you RL / RLC. The RLC will have no high speed compression though (dial on the bottom of the fork)only low speed. Top Cap Assemblies are about £50 plus vat from MOJO and dead simple to change.
You can only do this on Genuine Fox Forks and not OEM ones as the Top Cap thread pitch is different by 0.5mm.
Posted : 03/08/2012 10:02 am
Cannot see the top cap assembly on the mojo site.
Posted : 03/08/2012 11:24 am
