What? Gravel tyres ...
[Closed] What? Gravel tyres with a mud bias in 700x50ish size?
 a11y
After increasingly frequent unintentional off-piste excursions on my gravel bike, I accept I need tyres with deeper tread for current conditions and throughout winter. My current tyres are a bit too skitey at this time of year where I ride.
I'm looking at the Schwalbe G-One Ultrabite in 700x50. TBH they look like what I need, but I don't pay much attention to what's available in the gravel tyre market and wondering if there's others similar to this I should consider?
Looking for:
- 700x50ish/29x1.8" max;
- more grip than my current Clement Xplor MSO 700x50mm;
- tubeless;
- more bias towards muddy forest track than tarmac, but not utterly pish/draggy on tarmac.
My current tyres:
Ta.
Posted : 01/11/2021 11:52 am
What mudguards are they mister?
Posted : 01/11/2021 11:56 am
 a11y
@zippykona, SKS Edge AL56 bodged onto a fork with no mounts/eyelets etc. Hugely more rigid and no rattling compared to SKS Chromplastics I used before.
Posted : 01/11/2021 12:01 pm
These are probably a little narrow for what you want, but I'm impressed with both the mud-grip and the rolling speed of the Vittoria Tereno Wets 700x38.
Posted : 01/11/2021 12:16 pm
I hear good things about WTB Sendero
I really like my Pirelli Cinturato Dry on hard surfaces and road but they are not suited when there's a bit of mud, so have something of the same dilemma. The Cinturato Mixed Terrain supposed to be good also....
Posted : 01/11/2021 12:23 pm
 pdw
impressed with both the mud-grip and the rolling speed of the Vittoria Tereno Wets 700×38.
Likewise, but disappointed with the rate of wear.
Posted : 01/11/2021 12:41 pm
 a11y
@hardtailonly, I've got used to the comfort of bigger-volume so yes probably a tad narrow for me. Tread pattern looks useful though.
@honourablegeorge, that Cinturato Mixed Terrain tread pattern remind me of Smart Sams in 700 variety which I found decent but couldn't bodge them tubeless with any success. Possible option.
Posted : 01/11/2021 12:50 pm
Cinturato dry went on my Hunts without levers, inflated with a track pump, and lost no air, spot on as far as tubeless goes.
Posted : 01/11/2021 2:08 pm
 momo
Schwalbe G-One ultra bite in 45mm? £60 for a pair from merlin at the moment, I'm running them on my Camino. They hold pretty good road speed and are very capable in the slop.
Posted : 01/11/2021 2:41 pm
 a11y
@momo, thanks - I'd seen them but hadn't spotted the multi-buy offer! Just unsure on the width, I know it's only 5mm difference but I know that can make quite a difference in volume/comfort.
I've found them in 50mm for slightly more, however they're Performance line rather than the Evolution line: rated as slightly less durable and slightly worse rolling resistance. And, for better or worse, they're tan sidewalls. Probably the best I'm going to find though.
Posted : 01/11/2021 3:13 pm
Been running 700x45 Cinturano M for over a year on my Diverge - impressed by their durability having not punctured in that time/ good wear. Not an out and out mud tyre, but give good grip - most of my riding is on the ‘rough’ end of gravel but they’re not too bad on the road either.
Posted : 01/11/2021 3:57 pm
I have Recently put Teravail Rutland 650b 47mm on my bike for winter. Replacing Terrano dries of the same dimensions.
They are fairly narrow compared to the tyres i took off. But so far they seem to hit that roll ok grip ok sweet spot.
They do them in 700c
Lots of good reviews on the web
Posted : 01/11/2021 7:36 pm
 mboy
– 700x50ish/29×1.8″ max;
Loving your maths here... 29x1.8" is approx 700x45mm... 700x50 is near as dammit 29x2.0"... 🤷🏻‍♂️
I’m looking at the Schwalbe G-One Ultrabite in 700×50. TBH they look like what I need
I don't think you'll be disappointed... But probably go with the 45mm version for greater mud clearance and performance over the 50mm. 👍🏻
Posted : 02/11/2021 12:31 am
WTB Raddler here… in G2 casing. Excellent in the slop (well, for a gravel tyre.)
Posted : 02/11/2021 6:39 am
 a11y
Loving your maths here… 29×1.8″ is approx 700x45mm… 700×50 is near as dammit 29×2.0″… 🤷🏻‍♂️
Yep, just as well I don't work with numbers. Oh. (I meant 700x50 / 29xwhateveritis - translates to 1.97")
I don’t think you’ll be disappointed… But probably go with the 45mm version for greater mud clearance and performance over the 50mm. 👍🏻
Thanks. Luckily mud clearance isn't an issue for me as it's not a real gravel bike - Planet X's version of the Sonder Broken Road Ti. Despite the lower range model, I'm probably going for the 50mm for the extra comfort.
Posted : 02/11/2021 9:20 am
