what goes nicely wi...
[Closed] what goes nicely with a nevegal?
Rear nevegal is past its prime so before I just slap another on, I thought I'd ask around.
What makes a nice front or rear to go with it? The tyre is a 2.1 ust and most of my riding is in the peaks. Can't really go any wider at the rear but could maybe go a bit bigger in the front. Wondered if it might go nicely with a high roller or ardent up front.
Posted : 01/07/2012 7:10 am
chianti...?
Posted : 01/07/2012 7:15 am
Was always Blue Groove/Nevegal that was the correct combo. ๐Ÿ™‚
Posted : 01/07/2012 7:42 am
So I thought but the blue groove seems to have disappeared some time ago.
Posted : 01/07/2012 7:59 am
Pinch flat
Posted : 01/07/2012 8:09 am
Body armour for when the front end washes out?
Just slap a high roller on and be done with it.
Posted : 01/07/2012 8:13 am
A tyre boot for when the sidewall goes
Posted : 01/07/2012 8:15 am
Your legs when faced with an incline
Posted : 01/07/2012 8:17 am
 nbt
I've been using a weirwolf on the front with a nevegal on the back. very nice directional tyre.
Posted : 01/07/2012 9:27 am
StickE front & normal rear?
Posted : 01/07/2012 10:55 am
Posted : 01/07/2012 11:02 am
Stickee Blue Groove front, DTC Nevegal rear.
Best combo I've ever used.
They do drag a bit though. ๐Ÿ˜•
Shame they dont do the BG in 29".
Posted : 01/07/2012 11:15 am
Not a lot of love for the nevegal then? I've found them predictable and robust. I'd be happy to buy another but just wondered if I should consider anything else.
Posted : 01/07/2012 3:08 pm
I don't get the logic of the OP Q.
"this rear tyre works well. what front tyre should I use with it?"
erm...a front tyre that works well?
Posted : 01/07/2012 3:23 pm
Currently running a pair of nevegal and happy enough with them. The rear is worn and needs replacing. It's an opportunity to try something else on either end was all.
Posted : 01/07/2012 7:32 pm
Nevegals used to be much loved by the internet, but then the phase of the moon changed and they instantly became dangerous and terrifying, apparently.
Still I don't entirely understand the question. Are you looking for a front or a rear?
Posted : 01/07/2012 10:22 pm
I'm now left with one nevegal. I can stick it on the front to go with a better rear, or on the back to go with a good front. Right now I'm considering a 2.3 ust nevegal to go on the front and put the 2.1 on the back.
Posted : 01/07/2012 10:37 pm
I have a 2.7 Blue Groove on the front of my DH bike. It is a sight to behold.
Posted : 01/07/2012 10:54 pm
Considering that the 2.5 Nevegal is the size of a 2.7 Highroller, that's a proper bit of one-upmanship :mrgreen:
Onzadog... Assuming your nevegal is a DTC I'd stick it on the back, I like Nevegals but the DTC isn't a very good front tyre IMO, too pingy and a wee bit abrupt. Stick-e one works much better- but 2.35 Stick-e is too slow for most folks' xc taste I reckon.
(as an aside; I didn't like the UST ones at all, they seem less grippy than the standard ones and a bit deader too. I run standard ones tubeless and they've been spot on for me)
Posted : 01/07/2012 10:57 pm
FWIW, and not really answering the question, a 2.1 Nevegal makes a great front tyre and about as big as Minion 2.35. on the back i found them draggy as hell though.. go for an advantage 2.1 maybe on back. SB8 if it's dry (hah).
Posted : 01/07/2012 11:13 pm
chianti...?
Phew, glad it's not just my mind that comes up with odd connections too! ๐Ÿ™‚
Posted : 01/07/2012 11:28 pm
Schwalbe hans dampf or a conti mounting king 2. Light, fast, good grip and volume
Posted : 02/07/2012 1:52 am
