What fork are you r...
[Closed] What fork are you running on your Blue Pig?
Just aquired a new frame and had decided on an x fusion velvet dla 140mm in white. Of course the importer doesn't seem to have any in stock.
Owners, what fork do you run? I like the idea of a 150mm Rev but I do like climbing and will be riding up mountains as well as down.
Posted : 27/08/2012 10:27 am
Thought about getting Revs spaced down to 140?
Posted : 27/08/2012 10:34 am
I really want to be able to drop the travel approx 30mm for climbing
Posted : 27/08/2012 10:41 am
140 revs on mine, I think 150 would really effect its climbing ability.
140 work well, but I wouldnt want anymore.
Posted : 27/08/2012 10:43 am
Some 140mm forks would be great. I think the frames are designed in such a way that you don't need to drop the travel for climbs.
Posted : 27/08/2012 10:52 am
140 pikes.
rollindoughnut - Member
i'm not sure it's necessary on a blue pig, the steeper-than-average seat-tube does a good job of keeping the front wheel down, even on steep climbs.
Posted : 27/08/2012 10:53 am
Pikes on my mk 1. Match it perfectly though I rarely run them at 140, much more fun at 120ish with a slightly lower bb.
Posted : 27/08/2012 10:56 am
Would something like a 130mm Recon be a better choice then? It's easy to mentally escalate how knarly your bike is going to be.
I want to use it for things ranging from North Downs to Welsh mountains and for doing some jumping.
Posted : 27/08/2012 11:01 am
Get a different frame? Im selling a Cotic BFe if you're interested, that rides well with shorter forks.
Posted : 27/08/2012 11:03 am
I think you've missed the point davidtaylforth!
Posted : 27/08/2012 11:11 am
Obviously there will be a point at which the geometry of you bike can't handle above a given fork height. Going 80mm to 150, maight be a step too far for example. It also depends on the style of bike and what you use it for.
I ride a (formerly) 100mm Trance.I took its 100mm Tora and removed the "spacer", taking it to 130mm. More recently it has a 140mm Rev. Yes. I have had to adapt my riding position very slightly for steep climbing, simply perch a tiny bit further forward on the saddle and bend at the elbow a little more.
It's been nothing other than a slight adaptation. I honestly believe that 10mm on a slack bike like the Blue Pig is neither here or there.............and then there's the question of sag, you may gain 7mm. You wont notice.
Posted : 27/08/2012 11:12 am
Sektor?
Posted : 27/08/2012 11:18 am
Thank you cakefacesmallblock. Nice of you to inject a little science.
Posted : 27/08/2012 11:20 am
had a sektor, changed it to a lyric that i leave at 150mm.
Posted : 27/08/2012 11:50 am
The seat angle on the Blue Pig is so steep that you won't want to drop the forks for climbing. There's about 10mm variation either way in 140mm fork axle-crown length, so 130/140/150 doesn't matter as much as the actual A-C length.
Posted : 27/08/2012 12:07 pm
140mm Fox Float RL 15mm axle. Work fine for me.
Posted : 27/08/2012 12:12 pm
2005 Fox that were swapped over from my Kna Dawg Primo. It now has 150 coil Sektors ๐Ÿ˜€
Posted : 27/08/2012 4:25 pm
145mm Manitou Nixon elites on my PG MK II
climbs well. decends well.
enjoy
Posted : 27/08/2012 4:35 pm
140mm fox and rides lovely
Posted : 27/08/2012 5:16 pm
110-140 revs on mine. I do like being able to wing them down for steep climbs. AWESOME on the downhills.
Posted : 27/08/2012 5:22 pm
Rev's on mine with spacer recently removed to give me 160mm.... Doesn't hinder me on the climbs, possibly the best bike I've ever had
Posted : 27/08/2012 5:23 pm
Fox Float 36s, got them cheap with the plan to lower them to 140mm. Never have, probably never will.
Posted : 27/08/2012 7:27 pm
I used uturn Lyriks and Revelations in my Mmmbop... Revs at 140mm was the best allround, very rarely wanted to wind them down further.
Posted : 27/08/2012 7:32 pm
150mm Revs on mine, the steep seat angle and low BB means it climbs really well even at 150mm. I also have an Inbred and there's nothing that I can't get up on the Pig that I can on the Inbred.
If you try it and hate it then you can always space the Revs down.
Posted : 27/08/2012 9:32 pm
