Right I have added the hub, rim,spokes and shifter to my basket, going on a geared Soul frame, so what else do I need?
Sprocket
centrelock brake rotor
chain tensioner
I use one of these with the Alfine on my Alpine:
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=20325 ]http://www.chainreactioncycles.com/Models.aspx?ModelID=20325[/url]
Chain tensioner and sprocket added. What about crank, can I run a normal single or is there witchcraft involved in the fitting/chainline?
er, just measure the chainline (mid axle at back to sprocket), and use trial and error with spacers to get the mid-BB to chainring distance the same
Fitting kit, if it's not included with the hub. I think it's usually listed seperately.
Fitting kit is not usually with the hub.
To get the hub onto the bike and working you will need -
Hub
Fitting kit
Sprocket (either Alfine or Nexus)
Shifter (either Alfine or Nexus)
Chain tensioner
