What Chainring bolt...
[Closed] What Chainring bolts for converting SLX Double & Bash to 1x10
5 Users
As above, the ones I removed are too long so I ordered [url= http://www.evanscycles.com/products/id/single-chain-ring-bolts-ec006126 ]these[/url] and they are too short. Can anyone confirm what length I actually need before I order some more that are wrong!
Posted : 11/04/2014 8:15 pm
You sure they're too small? Website seems to imply smallest are designed for single ring.
http://www.ison-distribution.com/english/product.php?part=CRIDBADK
What chainring? I know my Works Components one is quite thick & needed "XL" single (5.5mm backnut)
Posted : 11/04/2014 8:28 pm
The backnut just catches enough to stop the chainring rotating but I wouldn't want to put any torque through it at all. It's a Works chainring, so I guess I'll also need the XL version with the 5.5mm backnut.
Thanks.
Posted : 11/04/2014 8:41 pm
The best chainring bolts
http://www.amazon.co.uk/Truvativ-11-6915-015-000-Steel-Spacer-Single/dp/B001GSQO3W
You heard it here first.
Posted : 11/04/2014 8:51 pm
Rob Hilton - Member
Agreed, there's none of those silly nuts, that need the special tool, that is a sod to use - just 2 Allen keys.
Posted : 11/04/2014 9:21 pm
I just left the bash on mine so the bolts stayed the same - helps keep the chain on and makes it much less sketchy feeling when you do bottom out!
Posted : 11/04/2014 9:36 pm
