what bike would you...
[Closed] what bike would you like to see made
that generally isn't atm or is but is too wildly expensive?
I'd like a C456 29er so i had the option of a longer fork but it'd still be light enough to pedal all day, I'd have a C456 26" if I fitted one
over to you Mr Richards
anyone else hankering for something that doesn't exist?
Posted : 12/01/2013 1:40 pm
Titanium Roadrat
Posted : 12/01/2013 1:42 pm
Yes a carbon orange 5. All the fun but much less weight.
Posted : 12/01/2013 1:43 pm
Alloy Soul:
Seriously - I used to be a 'steel is real' evangelist but I'm ok now. Would like a light, Easton alloy frame with Soul geometry.
Cross Check Disc.
A nice 853 tourer/cross bike that can take discs and has separate rack and mudguard eyelets. AT A REASONABLE PRICE.
If Merlin can sell Rock Lobster 853 frames at reasonable prices, other people can make decent value 853 frames too.
Posted : 12/01/2013 1:50 pm
a Giant TCR Advanced roadie which takes discs (or any decent carbon disc frame)
I would buy this tomorrow, and spec it with some tubeless rims (maybe carbon, such a Reynolds Assault CX).
We have carbon CX disc frames but no affordable, non-hideous carbon road frames.
Posted : 12/01/2013 1:56 pm
A sub £1000 36er rolling chassis.
£2000 seems to be the going rate which is way too much for a 'just for the sake of it' bike.
A 36" Inbred would be ideal. Won't hold my breath though!!
Posted : 12/01/2013 1:57 pm
An Ibis Mojo with internal cable routing. Running 4 cables on the top of a top tube sucks!
Posted : 12/01/2013 2:04 pm
Carbon Pomp.....
Posted : 12/01/2013 2:05 pm
A bike based on late 90's Kona geo, steel DB frame, rigid forks, V-brakes, full Deore groupset, for around £400. Would suit pretty much 90% of what the vast majority of people buying a basic mountain bike would need.
Posted : 12/01/2013 2:12 pm
What I was going to say was close enough to this.
Would like the option to fit discs and eyelets for mudguards and racks too.
Posted : 12/01/2013 2:21 pm
An Inbred designed for 26" x 3" tyres and 1 x ? drivetrain.
And a selection of 3" tyres weighing less than 1kg and costing less than £50.
Could also be run 650b with 'normal' size tyres and 2 or 3 x drivetrain.
Posted : 12/01/2013 2:26 pm
ragley G6
Posted : 12/01/2013 2:27 pm
I nice retro quality steel tourer where you could mix and match components as you could in the 80s. When my bike mixed campag shimano mavic simplex etc and I could pick all the nice bits I liked and choose my gear ratios from the board in the shop
Posted : 12/01/2013 2:29 pm
already available in other EU contries but not in the UK.. even if a brand sells in all countries like specialized etc
sensible everyday bikes with dynamo, guards rack etc
Posted : 12/01/2013 2:30 pm
 jimw
Reynolds 931 Cotic soul in large
Posted : 12/01/2013 2:32 pm
Like The idea of 3" 26 tyres and a Steel frame to match, ebb , campy hidden set., Low bb, built for a rigid Low a to c fork.
And fleegle bars with rise, Steel and in Chrome 😀
Chrome and flat Black.
Posted : 12/01/2013 2:34 pm
got one in alloy but other than that spot on 😀
Posted : 12/01/2013 2:58 pm
I'd like Ti jones diamond frame and fat truss fork.
Posted : 12/01/2013 2:59 pm
Carbon ss cross bike with discs
Posted : 12/01/2013 3:06 pm
My Kona Sutra is steel. Has a mixture of Shimano road and Mtb plus Truvativ on drivetrain etc.
Id like to see a bike that could be used for proper off road riding and also take a rack and full guards. Oh. That would be the original clockwork.
Got few years to decide yet. Going to build my own from 853 for my 50th.
Posted : 12/01/2013 3:15 pm
Carbon intense slope style, series 1. It will never happen.
Sounds like a Surly Ogre?
Posted : 12/01/2013 3:20 pm
TBH I've already got 2 bikes which tick almost all the boxes so...
Let's have a Super-Hemlock, with a little more rear tyre clearance, and lighter, and dropper post cable guides, and with tweaked geometry to get rid of the 2 degree adjuster headset. And that's it.
Posted : 12/01/2013 3:21 pm
What Dans said. It will happen, I just need to predict 6 numbers correctly....
Posted : 12/01/2013 3:29 pm
A 7lb (no more, no less) 6" travel trail bike, complete. With Di2. For less than £1000.
I fear it'll be a long wait. But my god it'll be the best bike ever.
Posted : 12/01/2013 3:32 pm
Not so much a bike but a material. Someone needs to work out how to add colour to carbon fibres. Imagine the possibilities. Tartan frames, checked handlebars?
Posted : 12/01/2013 3:38 pm
A slack 953 frame like an LTHT but with 2" of fairly stiff single pivot travel to go with a 140-150mm fork. Just a [i]little[/i] give for flexing into corners and a smidge for landings; but by no means a compensator. Single pivot for a single piece back end and low maintenance & no weird bearing sizes! CNCd tapered headtube, or maybe a machined hourglass 44mm? Offset insert thingybobies at the pivot for more tweakery of the geometry to match fork choices/preferences.
Polished or brushed, straight-ish tubes, swap-outs for fettling potential. Simple, stainless and with options. The bastard son of a softtail, 4x bike and a LTHT.
Posted : 12/01/2013 3:40 pm
Mostly Balanced - Member
Wouldn't be hard tbh, lots of existing carbon is basically a structural part, wallpapered so that people will go "ooh- carbon!"
Posted : 12/01/2013 3:42 pm
A Cotic Soul in Ti.
Posted : 12/01/2013 3:54 pm
A Ti Sovereign, with a 44mm headtube, that isn't priced relative to the crazy rrp the steel one had.
Posted : 12/01/2013 3:57 pm
warpcow - Member
Yep, tbh with Evil it'd cost £10000 and then there's a reasonable chance it'll fall apart and you'd have to wait 2 years for the replacement :mrgreen:
Posted : 12/01/2013 3:59 pm
A Monsterpetamine...
Pompino geometry, 2.5" clearances. Midge bars, BB7s.
Posted : 12/01/2013 4:06 pm
A Jones spaceframe with truss fork that I could run a rohloff on without any clutter
Posted : 12/01/2013 4:17 pm
26" ss ebb bike designed for low ac rigid forks and 2.5" tyres. That'd be me sorted...
Already exists, I can think of white, blue and red carbon parts.
Posted : 12/01/2013 4:21 pm
Someone really needs to place a Rohloff in the BB shell and attach the cranks to it, I don't get why its not been done.
A niche bike that doesn't attract enablers and apologists on here when it's obviously flawed, breaks too often or comes with poor customer service.
By all means praise a good product (but not just because it's cheap) but spare us the doe-eyed sycophancy, the taste of bile is bad enough how do you put up with that horrible acrid taste* on the end of your tongue?
*not being brown nosed im guessing what shite tastes like.
Posted : 12/01/2013 4:27 pm
Bring back The soft tail, i have never tried one, but like the idea of an inch to save my back.
Posted : 12/01/2013 5:25 pm
Torque
Posted : 12/01/2013 5:26 pm
Plus fat bottom brackets are ugly.
Next thing I'm building (well, next after this road frame) is a Hetchins. A 29er MTB Hetchins.
Posted : 12/01/2013 5:39 pm
An alu Santa Cruz TR, the carbon one is to much for my pocket! I'm hoping the new Cotic will be something along these lines.
Posted : 12/01/2013 5:54 pm
The original Klein attitude with press fit bb, press fit headset etc. Not the dumbed down Trek version, but the original.
That bike was way ahead of its time and would still kick ass today.
Posted : 12/01/2013 6:07 pm
They did, its called the Nicolai Nucleon.
Posted : 12/01/2013 6:59 pm
Carbon Chameleon.
Or a [u]not ugly[/u] 140mm capable 26" lightweight LT carbon hardtail*
Thanks.
* sorry Brant, I've tried to like it, honestly I have, but I can't, as it's ugly, sorry.
Posted : 12/01/2013 7:22 pm
 juan
A 65 BHP 177 kg fully loaded 4stroke monocylinder. Like a SRX 600, but with more juice and a stiffer frame 😀
Posted : 12/01/2013 7:36 pm
I'd like an AM bike with 140/150 mm travel front and back with lock out suspension on the handlebar. The Scott Spark is close but needed more travel. Guess I'll have to buy a tallboy and fit lockout to the shocks. Unless anybody has better idea?
Edit: it's needs to climb!
Posted : 12/01/2013 7:45 pm
ti_pin_man
[url= http://www.hotlines-uk.com/Models.aspx?ModelID=89034 ]Zesty 515 E:I[/url]
Posted : 12/01/2013 8:21 pm
A titanium version of my 1st generation Specialized Langster:
Straight blade carbon fork and hydraulic disc brakes. Tiny little discs with full internal hose routing and an internal hydraulic reservoir - inside the stem or something.
Also no rack mounts, only one set of bottle boss bolts, no cable stops. Super clean lines, all in raw Ti with black carbon forks. Yum.
Posted : 12/01/2013 8:27 pm
Belt drive Alfine, properly sealed, with close ratios for winter road training.
Posted : 12/01/2013 8:29 pm
A Cotic Soul or 26er Simple in 21", please. A 19" is just not large enough.
Posted : 12/01/2013 8:59 pm
Monsterpetamine +1
Posted : 12/01/2013 9:01 pm
I'd love to see a carbon fatbike and more importantly carbon tubeless compatible rims for it.
Low 20 ish lbs with a 1x10 drivetrain at that weight would be freaking awsum.
Posted : 12/01/2013 9:07 pm
like this one stu?
medium frame 3.5 lbs!
Posted : 12/01/2013 9:11 pm
Sorry forgot to say that i'd like it for less than a grand and without an on one sticker on it. 😆
Tazzy fail by way of no carbon rims. 😛
Even fatbike [b]frames[/b] have no reason to weigh much.
It's all about getting the wheel weight down.
Posted : 12/01/2013 9:14 pm
 ianv
Decent fs, 20 and 24 inch with decent geometry, light but strong 120 ish (air) suspension.
Sort of mini heckler sort of thing.
Posted : 12/01/2013 9:19 pm
bencooper - Member
I'd love to see that!
A friend of mine has just finished restoring his Hetchins-work of art.
Posted : 12/01/2013 9:20 pm
Zesty 515 would need fork lock out to match!
Carbon Soul in 18"
Polished 953 Solaris (I know they made one and it was a bit flexy but just looked stunning)
Always felt that the Yeti ASR-C and ASR-C5 were as close to perfection as it was possible to get.
Posted : 12/01/2013 9:27 pm
ti_pin_man
Climb setting on a CTD fork should be fine for all but the heaviest and most ungainly pedal mashers.
Posted : 12/01/2013 9:30 pm
A full suspension cyclocross bike that can take 2.1 inch tyres. Is there such a thing? Or even a front suspension cross bike that can take larger tyres?
Posted : 12/01/2013 9:50 pm
That's called a xc race bike.
There's loads of them about.
Posted : 12/01/2013 9:53 pm
But I want drop bars!
My race bike is a Whippet.
Posted : 12/01/2013 9:56 pm
Not very difficult to fit a dropbar to an MTB is it ...
Posted : 12/01/2013 9:58 pm
No, but heard having disc brakes with STI levers is from my LBS mechanic?
Posted : 12/01/2013 10:22 pm
Proper (IMHO) UK AM bike. Progressive 100-125mm out back, 150mm up front. Soul/BFe/Rocket geometry with an all-up weight around 28lbs with a toughish build.
Posted : 12/01/2013 10:55 pm
Small size Solaris /Soul 650b for 5'4" people!
Posted : 12/01/2013 11:04 pm
Yeti ASR-carbon 29er with integrated seatpost
Santa Cruz TRC with a pretty paint job (same can be said for the Tallboy)
Speedvagen 29er hardtail
Yeti ARC-x with disc brakes
100mm Cotic marathon bike
Posted : 12/01/2013 11:12 pm
 Bez
A stiff road/CX frameset with disc mounts and a 62cm seat tube, 71deg seat angle, 61cm top tube and 74deg head angle. Stick a Headshok in it for bonus marks.
Posted : 12/01/2013 11:19 pm
 hora
On Ones Burt didn't make the c456. He was flogging Ragleys on here at the time
Posted : 13/01/2013 10:26 am
a 24" wheeled steel frame town hack bike, ie geo not like a jump bike. built as heavy as a Soul or similar; can easy take steps but not for dirt jumps/jumps parks. 3-5 gears light and simple, disc brakes and rigid forks. rag it around town, walk it staight onto the train and takes v. little room. handy. and fun
also +1 for the ragley full sussers!
Posted : 13/01/2013 10:52 am
