What are these odd ...
[Closed] What are these odd washers which came with my Shimano Rotor?
As above - my new 160mm, 6 bolt rotor has arrived and it has three 'double' washers - they look like they're probably spring washers as they have a slight bend in them (if that makes any sense?!).
Should I use them? My Avid rotors had no such washers.... And if so, do they go between the rotor and the hub of on top of the rotor?
TIA..
Posted : 28/04/2010 5:18 pm
they are to stop it coming undone iirc, ignore them
Posted : 28/04/2010 5:20 pm
Had these on my old xt 4 pots theyre a lok washer that you bend a corner up on each end around a trianular bolt head. just bin them use normal hex heads and loctite.
Ah. Cheers guys - off to fit it right now....
Posted : 28/04/2010 5:21 pm
Done! New grips fitted too - off for a play round my local woods - hooray!
Posted : 28/04/2010 6:01 pm
