What Are THE Go-To ...
[Closed] What Are THE Go-To Brakes These Days?
Hi all.
I've kind of lost touch with whats what with bike components in the last couple of years and I believe my mk1 SLX brakes are beyond salvation so I'm wondering what I should replace them with. General trail riding, lots of trail centres, some enduro racing... Are Zee overkill? SLX/XT just as good but lighter? Already have Shimano floaty rotors so don't really want to get rid of those so thinking that sticking with Shimano is the way to go...
Dave
Posted : 20/01/2016 2:27 pm
New SLX are a winner. Zee are heavier, but a lot of people like the increased feel they offer (as well as power) - so also a winner.
Other brands are available, but you can't really go wrong with either of the above.
Posted : 20/01/2016 2:29 pm
I cannot fault deore and see no reason to go higher up the range tbh
Posted : 20/01/2016 2:39 pm
I have zees, XT and Deore, the Zees are great in terms of modulation and overall power, the Deores are amazing though and I'm not sure I'd pay more, I prefer them to my XTs though they are a few years newer.
Posted : 20/01/2016 2:40 pm
My tuppence.
I would have avoided Avid, but my last two pairs of Elixir's and DB5's have been faultless and cheap. Outright power is on a par with Shimano, but they're more progressive rather than the more on/off feel of the Shimano servo wave brakes. They also seem to have dropped the Avid name from all but the cheapest models which I'd take as an admission that things weren't right and they've improved if they're prepared to re-brand them under SRAM.
I've also got Shimano XT's, as I said, different, but no more powerful when used hard. The downside of Shimano is the rotors, there have been several cases of people melting Ice tech rotors, apparently they work well for cooling your brakes, but only upto a point then they fail catastrophically! They also have an incredibly thin steel surface, so I'd hesitate using them in winter too unless I was minted. Having said all that, you could use the standard rotors and be no worse off than using Avid/SRAM.
Posted : 20/01/2016 2:41 pm
+deore here, great brakes.
There's load of brakes on the classifieds at the moment. & if you buy new have a look at merlin and they offer through quidco too.
Posted : 20/01/2016 2:44 pm
The older style XTR trails are simply awful. In fact I command you to ditch any that you may have lying about and pass them on directly me, I can look after them.. 😉
Posted : 20/01/2016 2:45 pm
I've been a total XT whore but have just got Hope Tech3 V4. Amazingly different. In a good way.
Posted : 20/01/2016 2:48 pm
My Crush came with some Deore 615s which are as good as any brake I've ever used. Plenty of power & decent modulation, just look a bit plain jane is all.
Posted : 20/01/2016 2:53 pm
junior has 2015 Deore, I have 2015 SLX on one bike and 2013 XT on other. All feel the same and all good. I just the other day had to replace the rear lever on the XT's, which was losing it's snappy return, but it has had a lot of use, so not complaining and new one was only £20 or so.
Posted : 20/01/2016 2:56 pm
Have got 4 sets of Shimano on the go 396/Deore/Zee/XT no problems with any of them
Zee feels like the others until you pull hard. Caliper is a big old brick though you've got to really want them for normal trail riding
396s are dirt cheap they're like Juicys that actually work
Deore for value, XT for looks
Hope better than all of them by a fair margin
Posted : 20/01/2016 2:59 pm
Had SLX and am currently running Zee and XT. I'd agree with the above.
I'd also go so far as to say; if you're thinking of XTs then go for the Zees. They're not much more when purchased from Germany and worth the extra.
Posted : 20/01/2016 3:07 pm
Deore M615, bargain for how good they are!
Posted : 20/01/2016 3:13 pm
M615 +10
Posted : 20/01/2016 3:24 pm
I've just recently picked up some Magura MT5s. Light, absolutely loads of power and lots more modulation/feel than the Shimanos I've tried although I wouldn't be disappointed . Definitely feel I can use my brakes more effectively. 5 year warranty too. I paid 150 euros for a proper retail set so they aren't too pricey either.
[url= http://enduro-mtb.com/magazin/viewer/?issuenr=015 ]Enduro Mag group test[/url]
Posted : 20/01/2016 3:25 pm
Exactly this. I'd not used Hopes in years and was a little nervous but so far they have exceeded the standard set by various Shimanos. the Tech 3 V4's offer massive power but have great modulation so better control. I also quite like the chunky manufactured look and they feel solid
Posted : 20/01/2016 3:29 pm
OK, cheers all, doesn't sound like I can go too wrong with any Shimanos then.
Posted : 20/01/2016 4:23 pm
 Del
[url= http://singletrackworld.com/forum/topic/whats-up-with-my-xt-brakes ]there's a few posts here that contradict the universal approval of shimano brakes[/url]
Posted : 20/01/2016 4:36 pm
I've just recommended some deore to someone. For the money I think they are superb and have much better modulation than XTs. Actually wish I'd taken them off my old bike and kept them instead of the XTs.
Higher up the price range I really liked the SRAM Guide too when I tried them on a Nomad. Again, lovely modulation and good power.
Yet to try Zee, Saint or Hope but I really think I'd struggle to justify spending more than ~£70 for Deore if I needed a new set.
Posted : 20/01/2016 4:40 pm
50g a wheel heavier than SLX iirc, so barely worth mentioning really
Posted : 20/01/2016 4:49 pm
I've run shimano on various bikes over last 10 years, cheap and get the job done... But, most recent set have the dodgy lever feel
As it happens, just put an old set of hopes on my commuter, 15 year old mini's (I think, that long ago I can't remember), had them rebuilt by lbs who got new seals from hope, feel as good as new
For that reason I'll be moving to Hope
Posted : 20/01/2016 5:30 pm
My Shimano hydro road brakes have been faultless, my Shimano XTR (M988, M9020) have been riddled with faults.
I've gone for Hope for my MTBs and for the first time in recent memory, I completely forgot about my brakes after the first 5 mins. Far superior to the ever present "?" as to what my Shimano brakes will do next.
Brake well? Howl like a banshee? Need multiple pulls to stop? Throw me over the bars as I've over compensated.
Oh, and at the very least, the BPC on Hope brakes actually does something, which it doesn't on XTRs!
Posted : 20/01/2016 5:46 pm
Saints on both bikes, they work brilliantly, they are nicely and easily adjustable, I guess overkill but I'd rather be over braked than under braked, as I was in Pila with Formula R1's.
Posted : 20/01/2016 8:18 pm
Same as most things bike nowadays, there are few bad brakes around. I have had new XTs, Guides and hope E4s. All good in their own way. All reliable and easy to bleed.
Posted : 20/01/2016 8:48 pm
 poah
Zee from Zee germans
Posted : 20/01/2016 10:13 pm
Adam_Buckland - Member
As Adam said. I love the modulation and reliability of Hope, plus their awesome service if any issues.
Posted : 20/01/2016 10:25 pm
 pnik
I got some slx from merlin to replace my old slx, they are fine good even i love my hope m4s on the other bike, they aregood but for the money shimano, my only issue with shimanos is no spares if a problem isnt pads or a bleed its time to replace, but for me no brainer unless youve budget to pimp your ride.
I had some mono minis 10 years ago they were very bad.
Posted : 20/01/2016 10:56 pm
Shimano Shimano Shimano 🙄
IMO SRAM Guides are far superior and can be had for cheap as folk take them straight off new bikes to replace with sh*mano.
I just don't get it - every set of Shimano brakes I've used have felt flimsy power-wise.
Posted : 20/01/2016 11:03 pm
Dunno about that. I've only had XT on my bikes and they have been fine. The Hope just add something in the way of control I was unaware of.
Posted : 20/01/2016 11:08 pm
I'm with Jimmy on the SRAM Guides...defiantly worth a punt if they come up cheap.
Posted : 20/01/2016 11:20 pm
Sram guides.. 😀
Posted : 21/01/2016 10:41 am
SRAM Guides on my new bike and they're superb.
XT, XTR and Saint on my other bikes and they require almost constant attention
Posted : 21/01/2016 10:52 am
I've had a fair few pairs of Shimano brakes and most have been very good.
I had some XT 785's that I was never totally convinced by; power was good but the lever feel was always a bit 'mushy'. At the same time, my hardtail had some older Deores (pre Ice tech compatibility) and these were ace for £60. The current 615 Deore's which replaced the older ones are brilliant for £60 a pair and I found they were much easier to get a good bleed and solid lever feel with.
My big bike had Zees which were good - solid lever feel, lots of power and more feel than my 785's.
My current Ti hardtail has XTR Trail brakes and the jury is currently out - I've had to bleed them a couple of times and if they place up again, they'll be returned.
Posted : 21/01/2016 10:56 am
I've found Shimano XT to be more reliable and more powerful than Hope. They're also half the cost.
Posted : 21/01/2016 11:39 am
and use mineral oil, which (unlike dot fluid) won't scrape your face off with a chisel if you look at it funny.
Posted : 21/01/2016 12:41 pm
XT get my vote. Even Deore are cracking brakes if you've got shallower pockets.
Posted : 21/01/2016 1:37 pm
It's gone full circle, Hope. 😀
SLX, unless you want on the fly reach adjust, in which case XT.
Posted : 21/01/2016 1:54 pm
I wonder how many people on these threads are comparing current brakes or historic experience...
FWIW:
I'm talking about Shimano R685/785 levers (I have both) on XTR M9020 Callipers for my road bikes and XTR M988/9020 trail brakes and Hope Tech 3 E4 and X2.
Posted : 21/01/2016 2:55 pm
Been looking for something to replace my formula T1S as I fancied something different, so plumped for some XT m8000 with XT (not the ice-tec) rotors
Should be here tomorrow so I'll report back once they on and tested!
Posted : 21/01/2016 8:42 pm
There turned up and look "velly niiiice!"
Off to fit them now...,
Posted : 22/01/2016 6:20 pm
