Weldtite TF2 lubric...
[Closed] Weldtite TF2 lubricant spray can - On fork stanctions?
Anyone got the above lube. Got a can for a few quid from tesco's. It has teflon in it.Wondered if it was ok for forks. Mr Tim Flooks seems to think teflon is ok ( well chain lube with teflon in)
What else have you used it for successfully?
Posted : 09/06/2010 1:32 pm
I've used it for a variety of applications, chain lube, cables, mech pivots, frame cleaner etc plus I've used to degrease bearings and the like. It's better than WD40 'cos it doesn't leave as 'wet' a residue.
Not used it on fork seals, I use Brunox Deo for that and I can heartily recommend it.
Posted : 09/06/2010 1:40 pm
thanks.
Posted : 09/06/2010 1:47 pm
I'd avoid introducing anything containing solvents into your fork oil tbh
Posted : 09/06/2010 1:48 pm
ok thanks.think i'll get some fork juice then.
Posted : 09/06/2010 1:49 pm
I happily use a silicon lubricant spray on the forks/shock
(this come in the form of car dash-board cleaner or something similar)
Posted : 09/06/2010 1:54 pm
TF2 spray is really very similiar to WD40, it's the same basic ingredients mixed up slightly differently, with some extra stuff so they can say it's different and with a tiny amount of ptfe so they can say "contains teflon".
Fork Juice seems to be just slightly overpriced silicon lubricant... But that's OK, it comes in a nice can and it lasts forever. Fork oil is another good option but it does attract dust.
Posted : 09/06/2010 1:55 pm
ok i'll use some silicon spray now.
Posted : 09/06/2010 2:10 pm
I like fork juice - certainly makes the forks plusher (in the short term) and lifts a lot of crap out of the seals which must be a good thing (although other sprays may do this - i have not tried anything else).
Posted : 09/06/2010 2:39 pm
Why not just use chain lube? Finish Line Wet seems to work perfectly for me.
Posted : 09/06/2010 7:12 pm
i've always put a bit on my forks and its always been fine
Posted : 09/06/2010 7:17 pm
