First of I know I don't have the lightest frame to start with and yes I acknowledge the limitations of loosing weight with a steel framed build
Thought I would get that ^^ off of my chest first 😆
As pictured the bike currently weighs 24.2lbs and is a Large frame
Am I kidding myself that it could weigh much less without spending mega bucks 😕
[b]Pic: [/b]
[b]Spec: [/b]
Frame: 2010 Pipedream Sirius 853 (19’’)
Fork: 2010 Rockshox Recon Race 120mm
Headset: Ritchey WCS
Stem: Thomson 100mm
Handlebar: Easton Monkey Bar
Brakes: Marura Louise BAT
Cassette: Superstar Components SS kit
Chain: SRAM PC1
Cranks: Middleburn RS7
Chainring: Middleburn Uno
Bottom Bracket: Shimano Square Taper
Pedals: Shimano
Hub Skewers: Ringle
Rims: DT (Branded Magura)
Hubs: DT (Branded Magura)
Nipples: DT
Spokes: DT
Saddle: SDG Ti
Seatpost: Hope
Seatpost Binder: Hope
Define mega bucks.
Swap Recons for SIDs
Swap Thomson stem for one of the many lighter choices
Swap bars for light carbon ones
Non-QR seat clamp
Hubs may well be heavy depending on what model they actually are
Hope seatpost isn't light IIRC
Ditto the saddle
I can't see the pic here, but my first bet would be tyres, then rims.
any weight you loose you won't notice - unless you spend mega bucks, in which case a Ti frame might be a starting point
Cut the steerer.
Oh and lighter pedals - normal SPD ones rather than caged.
Looks very very nice as it is.
Is the weight bugging you?
SB
that weighs less than my road bike.
At 24lb I'd be extremely smug.
If you want to lose three quarters of a pound off it then you could swap to Eggbeater pedals or even Crank Bros Candys.
You might also lose a bit of weight swapping to an I-Beam post and saddle and going ghetto tubeless.
ghetto tubeless isn't a weight-saver.
i tried it and i weighed it.
you take out 200grams of 26" innertube, and put in 100grams of 20" innertube, and 100grams of sealant.
and 50 grams of electrical tape building up the rim, and you still have to carry an inner tube in case it goes wrong.
Why d'you want/need it lighter?
Sounds a nice weight, but are the wheels heavy? I know some DT rims can be a bit weighty.
I've got my handjob down to around 24 or 25lb and wouldn't want it much lighter really.
My large Scandal weighs 23lb, it has gears.
Change the frame, those new pipedreams weigh a ton.
Light weight wheels and forks. Sids, rebas for the forks.
Hope hoops for the wheels with stan's 355 rims run tubeless with a light set of tyres.
As above though, what bugs you about the weight, it makes a difference but shaving a few 100g won't massively change the ride.
rigid fork...?
silly light tubes? what tyres you running? could probably loose some weight, but all with potential handling/reliability issues in some circumstances.
Shorten the brake hoses. And stop worrying.
Conti Speed king (or Race king) supersonics with conti supersonic innertubes would probably get it to 23lbs, tho I can't vouch for their performance.
Cheers for all of the comments and suggestions.
Weight savings noted - will look into pedals
The plan all along with this build was to get a SS up together that would be competent to race in some novice races around Thetford this winter.
The only reason I inquired about the weight is that I would like the bike to be in the best condition it can be in ..... within reason (££)
Then I only have the rider to blame 😆
BTW: Tyres are IRC Mibros (or something like that) circa 520g each as they are 2.1s
You could lose 1/2 pound by swapping the saddle and seatpost - but it would cost the best part of £200 though for an SLR saddle and KCNC seatpost!!
Have a poo before you ride it.
+1.
Also, how much do you weigh? If you're carrying an extra couple of stone, maybe think about losing that first.. 😀
Rigid fork is the obvious thing for losing the most weight.
Then lighter tyres.
Then lighter wheels.
And you could still get a steel frame and get it under 20lbs. My mate has several steel framed bikes that are 17-19lbs. But maybe not with that pipedream, I've heard its a fatty.
If you went for some lighter wheels, you could get some v brake rims, which means you could go for really light hubs, and then get v brakes and lose some weight.
Start with tyres, tubes, then go to rims spokes and hubs. Ive just got some hope hoops with the pro2s and stans crest rims. They aren't ridiculously light but quite good for the money.
There was someone selling Ti seatposts on ebay a while ago for £45, were fairly light i think. Also you can get a saddle off ebay for £30 that weights just under 200 grams claimed weight. Ive not checked but its very light. here it is - http://cgi.ebay.co.uk/bioflex-carbon-base-titanium-rail-190grams-bike-saddle-/270582781059?cmd=ViewItem&pt=UK_sportsleisure_cycling_bikeparts_SR&hash=item3efffd9483
saying all that 24lbs is good. I think my 18" inbred weighs around that with stupid light stans tyres. Should be able to get it a little lower if i put them on my new hope hoops wheels however im going down the nobby nic/racing ralph route. Still should lose a bit of weight though. deore hubs/317 rims and non butted spokes are HEAVVYYY
edit: realman has a point. Nice rigid exotic/pace fork made of CF will reduce the weight loads!
40mm stem, 1 finger brake levers, slick tyres.
That seems light already! Over the last 18months I've been perfecting a similarish bike (duster, though with gears)
My plan of action for your bike would be -
cheapish upgrades....
Foam grips....I like the superstar ones
New Qr's...again I use superstar ones
ibeam saddle and post (even though I've broken 2 posts I'd still use them)
ashima rotors
pedals
schwalbe tyres (2.1 RRon / RRalph)
expensive upgrades...
reba SLs / SIDs
carbon bars, probably eastons
new wheels, proIII crest
I'm pretty sure BATs are quite heavy so could save 200g ish by going to hope tech x2s (though the older mini's are slightly lighter...)
new frame 🙂
It weighs only a bit lighter than my (large) 456Ti, and that has gears!
Try an SDG I-Beam seat and post, non-QR seatpost clamp, replace all steel bolts with Ti bolts, carbon bar and lighter stem (Easton EA90?).
And lose the surplus bottle cage bolts.
And if feeling wealthy, Formula R1 brakes.
are you sure it weighs 24lb - i am doubtful
I was at the shop when Mark picked it up and it weighed 26lbs on the scales then. So if he has replaced anything since, he has lost 2lbs already.
personally, if you want to be competent in races then you need gears
