Waterproof paper - ...
[Closed] Waterproof paper - inkjet printer
[#7397935]
For printing maps, does it work? Something like Memory Map Tough Print.
Or am best finding some skinny laminating pouches? Needs to be fairly apocalypse proof.
Posted : 17/10/2015 10:31 am
The paper is brilliant, much better than laminating.
Posted : 17/10/2015 10:38 am
Is your ink waterproof? Professionally printed waterproof maps can be great, but even with some of those I've experienced print rubbing off. For personal use either, then either use a laminator, clear sticky backed plastic or sealed plastic bags - have used all of those with success in very wet conditions, including kayaking.
Posted : 17/10/2015 10:40 am
I think that's one also far.
It's just a bog standard inkjet printer.
Posted : 17/10/2015 10:55 am
Ive always found laminated maps a bit if a pain as they are too stiff to fold. My preference is to cover with that sticky-backed plastic film sold in rolls. I've loads of full OS maps that have survived repeated abuse. Might be a bit of a pain if you are making loads of copies for an event or something though.
Posted : 17/10/2015 11:01 am
It's for personal use, you got a link to that film?
Maybe the nuclear option is to buy tough paper then cover it in film.
Posted : 17/10/2015 11:09 am
http://www.amazon.co.uk/Cover-Film-For-Books-Etc/dp/B000TBYL46
This sort of stuff.
other retailers/outlets/brands are available (inc WH Smiths)
Posted : 17/10/2015 11:12 am
Exactly what I was describing as "clear sticky backed plastic". Often referred to as "soft laminating"
Posted : 17/10/2015 12:27 pm
 km79
Never had a problem in using ordinary A4 map printouts and using one of these drybags.
https://www.ortlieb.com/en/produkt-details/?produkt=documentbag&list=schutzbeutel&slug=schutzbeutel&clearname=Protective%20Cases
Posted : 17/10/2015 1:32 pm
I'm really after the most compact waterproof option I can get.
I'll give that film stuff a bash.
Posted : 17/10/2015 2:56 pm
