warranty? or not..
[Closed] warranty? or not..
[#6702779]
Hi STW.
My road bike has a 5 year warranty.it was bought summer 2012, and sees up to 2.5k miles a year...
It has never been dropped or crashed but the bottle cage mount screw has started to come away and flap off. It is a mushroom rivet around the screw, is all I can think of to describe it.
Any ideas if this would typically be warranty?
It is currently with the company but they are taking their high time about getting back to anyone....
Cheers all!
Posted : 13/12/2014 1:44 pm
Put a new rivnut in....5 minute job.
Posted : 13/12/2014 1:47 pm
Dealer can fix in 2 mins with a Rivnutt tool.
It's the retailers responsibility to resolve this. What have they suggested?
Posted : 13/12/2014 1:48 pm
a non critical part working loose after 7 k ish miles use is not a waranty issue IMHO
Fixing it would have been very easy
Posted : 13/12/2014 2:11 pm
Ask the retailer
Posted : 13/12/2014 2:12 pm
As stated it is with the company....
It is beyond a rivnut tool apparently. They usually would do that.
Posted : 13/12/2014 2:52 pm
Drill it out and fit a new rivnut then?
Posted : 13/12/2014 3:00 pm
The "company" do you mean the shop that you bought it from ?
I wouldn't be without my bike over something like this, you need one of these, the tool to fit it start at just over a tenner
http://www.ebay.co.uk/itm/Aluminium-Grooved-Serrated-Knurled-Large-Head-Rivnuts-Rivet-Nuts-Nutserts-/251438071410?pt=UK_DIY_Material_Nails_Fixing_MJ&var=&hash=item3a8ae07e72
Posted : 13/12/2014 4:39 pm
Drilling a rivnut results in the larger swaged internal part falling inside the frame/tubing. Sometimes its then impossible to get them out if the inside of the BB shell or headtube isn't drilled. A Cannondale Prophet I bought offf Ebay had this problem. I squirted a bit of expanding foam in via the new rivnut to stop the one inside rattling.
Posted : 13/12/2014 5:45 pm
It's got a 5 year warranty and a part of the frame has failed. Clear warranty job IMO.
Posted : 13/12/2014 5:50 pm
You can rattle the flared internal part out of BB breather hole.
Posted : 13/12/2014 7:35 pm
Yeah, I wouldn't be happy having an integral part of my frame bodged as a fix.
I had a frame replaced under warranty "just" for premature/unexpected corrosion.
Posted : 14/12/2014 11:39 pm
POSTED 1 DAY AGO # REPORT-POST
How do you know it hasn't been overtightened ?
Posted : 14/12/2014 11:54 pm
I saw a cube with a similar issue once but rather than the rivnut coming loose, the material around the rivnut had come away resulting in a larger hole. That was warranted though.
Posted : 14/12/2014 11:59 pm
