on one website appe...
[Closed] on one website appears to have changed fork lengths on some of their frames
am i correct in thinking the lot drop out inbred and scandal used to be advertised as 100-130mm forks, now both say 100 max. or have the geomtries changed?
Oh and anyone any idea how much the carbon 456 frames are going to be?
Posted : 01/04/2010 9:09 pm
i noticed that too.. can't help though
Posted : 01/04/2010 9:18 pm
something to do with CEN (is that what its called?) testing? Frames are no longer considered strong enough for longer forks
Posted : 01/04/2010 9:27 pm
ah ok thei'm right in thinking they we strong enough pre CEN they are rpobably still strong enough now just can' get the certs for them
Posted : 01/04/2010 9:31 pm
Always said the Scandal was a 100mm frame with delusions of grandeur. Just because a frame's strong enough for a longer fork doesn't mean it's a good idea
Posted : 01/04/2010 9:50 pm
i never undetood why the inbred was deemed good for a fork up to 130 but the scandal not since i thought they were exactly the sme geometry. i understand it may be better at 100mm for racing on, but for general ridig what makes it so bad to go above 100?
Posted : 01/04/2010 10:05 pm
For me, it just got ponderous. High BB, pretty long, was i think the main issue, but tbh I don't have the sort of head that can translate riding into numbers... I just found it to be a wee bit of a barge. An Inbred would have been exactly the same.
Posted : 01/04/2010 10:32 pm
scandal was always advertised as 80-100mm
Posted : 01/04/2010 10:44 pm
No it wasn't... The old website said
"Race proven by many (our racers tend to run the 29in model) this is a superb handling frameset that can be set up with any fork from 80-100mm right up to 130mm. It's attitude changes a little as fork length increases, but it's always fun."
Posted : 01/04/2010 10:50 pm
can't be arsed to argue so you must be right, but the 29er was always 100mm max as that's what I have, you small wheel boys must need bigger forks ๐Ÿ˜€
Posted : 01/04/2010 10:53 pm
Can't speak for the 29er, so you'll probably be right there.
Posted : 02/04/2010 12:29 am
