Vee Crown Gem 27.5 ...
[Closed] Vee Crown Gem 27.5 - any users? Or any other 2.6-2.8(skinny) tough rubber.
Hi,
Trailblazer sucks. Need replacing rear rubber. Don't like Schwalbe, Maxxis seems extortionately expensive in flavor I'd like it to be, no WTB anymore, found Vee Crown Gem and it looks interesting...
Any real life experience? Especially regarding actual vs. declared width and weight wise as well?
2.6, 2.8 or 3.0... Need to have some reference point to start up with something...
Unless anybody got other ideas for 2.6, skinny 2.8 rear tyre for mixed terrain (Peaks, Lakes).
I'm after traction and relatively robust side walls.
Trailblazer is shocking in that last department 🙁
Cheers!
I.
Posted : 30/03/2017 11:49 am
I'm a Vee user but not plus size. The new enduro core is great, not sure how that compares to the plus size sidewalls.
Posted : 30/03/2017 1:54 pm
Not all WTB Plus tyres are created equal. Do a bit of reading on MTBR.
Posted : 30/03/2017 2:05 pm
Thanks for suggestion. Having a peak now.
Cheers!
I.
Posted : 30/03/2017 3:48 pm
Specialized's Butcher 2.6 is not available over here apparently (though I've not been able to find any online, but they are available). That looks like a good bet based on the price of other Specialized tyres.
Posted : 30/03/2017 3:53 pm
WTB Ranger TCS Tough 2.8 is pretty much bombproof and around the same size as a Trailblazer and not insanely expensive either. A little heavy, but that's the price you pay for having super robust sidewalls. Not quite as fast as the TB, but not far off. Decent rear tyre, mix with something grippier on the front.
Posted : 30/03/2017 4:01 pm
Hi,
Thanks for more wisdom.
I have Surly Nate up front, so not much else to be done in front grip department :mrgreen:
But I'm seriously lacking traction up rear.
Legs still going but rear end is skipping and sliding.
... and these dreaded side walls 👿
Cheers!
I.
Posted : 30/03/2017 4:25 pm
 sv
+1 for BWD ^^^
I use a Ranger tough/fast as the light/fast cut on its second outing
Posted : 30/03/2017 4:54 pm
Hi,
Managed Ranger Tough for 32 quid, bought a bit on faith, but fitting outcome proved to be OK.
If lucky will give it a bash on Easter Monday...
However fitting this rubber into i35 ASYM rim is grim nightmare 👿
Plastic levers snapping, steel core lever bending, knuckles bloody-raw...
I understand that it is tubeless ready set-up, promoting easy inflation but fitting poops big time...
Sometimes I'm thinking that someone that designed WTB TCS system decided to take a mickey and all the 650b rims are in fact 652b...
Cheers!
I.
Posted : 10/04/2017 10:15 pm
Nobby Nic
Posted : 10/04/2017 10:26 pm
 Alex
I shredded a fast rolling Ranger at Afan but based on BWD's recommendation bought the Tough ranger a couple of weeks ago for £33. That's less than half the price of the Rekon on the front. It's been down the Ranger path off Snowdon, round the Beast at Coed and some decent length riding round here (FOD).
I felt it actually hit the rim when I cased a water bar and it survived that plus my other rubbish riding so it's a thumbs up from me. Not super grippy and quite heavy but as BWD says, that's the compromise. I'll be taking it to Spain in 10 days (but I'll also be taking a spare tyre)
I did manage to roll it off the rim a bit which strangely didn't seem to affect it at the time but it was flat in the morning. A quick bump with the compressor and it's not lost a PSI since. I'm running it at 18 now on the back of my FS - started at 16.
Posted : 11/04/2017 8:19 am
 Alex
Oh and I didn't find i hard to fit to 35mm rims - IBIS ones tho not WTB. Seems odd their own tyres are hard to fit on their own rims!
Posted : 11/04/2017 8:20 am
scotroutes - Member
Nobby Nic
No thank you very much. Don't like Schwalbe rubber.
Alex - Member
It must be definitely better than TrailBlazer, as it does not grip at all...
Not fussed about weight as have 1400g Nate up front :mrgreen:
Cheers!
I.
Posted : 11/04/2017 10:45 am
[quote=IvanMTB ]
scotroutes - Member
Nobby Nic
Nose. Face. Spite.
TBH, I've never much liked Nobby Nics in their normal variety but these are superb.
Posted : 11/04/2017 10:47 am
I'm sorta schalbo-phobic...
Too many bad experiences with them in the past.
Might be they are better these days but I'm not taking any chance 😆
Cheers!
I.
Posted : 11/04/2017 10:53 am
 Alex
I had a pair of the 2.8s NNs come with the bike. I'll certainly re-fit the rear when we're back from Spain. Probably leave the Rekon on the front tho. That's a really good tyre - should be for the cash tho!
Posted : 11/04/2017 11:05 am
