Vaseline to help se...
[Closed] Vaseline to help seat tubeless tire - can it damage the tire or sealant?
I'm a fan of using vaseline to help mount my Conti GP5000 TLs, put a tiny bit around the bead and in the hooks for the tire and it inflates beautifully with a hand pump. Works better than soapy water in my experience.
Some people seem to think it can degrade the tire and sealant (if latex based, I use orange seal endurance), personally I think it's fine, is it?
Posted : 20/11/2020 4:52 pm
I'd say you are safe, it is gentle enough to use in lip balm so I cant see it eating away at rubber.
Posted : 20/11/2020 4:58 pm
Just wait until you have to brake hard, and the tyre rotates on the rim and you keep going ๐Ÿ˜†
NB this probably won't happen, but please video yourself just in case.
Posted : 20/11/2020 5:18 pm
Vaseline degrades condoms (latex), so you shouldn't use it for any activity that needs a condom.
It can also degrade natural rubber, but I can't imagine a smidge on your rim is going to hurt (fnarr).
Posted : 20/11/2020 5:36 pm
Don't use soapy wster, use watery soap. 😉
Posted : 20/11/2020 5:38 pm
I'd go with a hard* nope.
Mineral oils (and vaseline) degrade latex (sealent, rubber in tyres), you don't need to be a materials scientist to know that, remember sex ed?
Use something silicone or PEG based.
*subtle pun intended.
[dammit, beaten** to it by 17 minutes as I had the tab open but got sidetracked by paper canoes]
**fnarr fnarr
Posted : 20/11/2020 5:53 pm
Lol..
Wonder if it makes it easier for the tire to unmount too, there soapy water could be better as it dries up.. hmmmmmmmmmmmmmmmmmmmmmm
Posted : 20/11/2020 6:00 pm
Actually vaseline didnt make it unseat from the rim bed more easily.
Posted : 20/11/2020 10:20 pm
A water based lubricant is the way to go. It does lead to some awkward conversations as to why you have sex lube in your workshop.
Posted : 20/11/2020 10:35 pm
I used the silicone spray I normally use on my stanchions the other day- worked really well
Posted : 20/11/2020 10:47 pm
Shampoo for the win.
Posted : 20/11/2020 10:58 pm
I use a silicone spray readily available from Screwfix.
Posted : 20/11/2020 11:11 pm
Posted : 20/11/2020 11:38 pm
