V1 Hightower - Car ...
[Closed] V1 Hightower - Car Roof Rack ?
10 Users
Can anyone recommend a roof rack for SC Hightower V1 frame so I don't need to take bottle cage on and off each time ?
Posted : 17/05/2021 11:35 am
Sort of. I solved this by swapping to the fidlock bottle system rather than changing the bike rack!
Posted : 17/05/2021 11:41 am
I have a thule thrutide for my bike, means taking off the wheel though
https://www.mbr.co.uk/reviews/products/thule-thruride-roof-rack
Had a V1 Hightower, bought one of these: Inno
Still using it 4 years later. Brilliant and doesn't damage frames unlike the Thule ones that clamp the downtube.
Posted : 17/05/2021 11:59 am
I have a yakima highroad which holds on the wheels, doesn't look like it will take longer wheelbases though
highroad
Posted : 17/05/2021 12:16 pm
I've just bought a Thule UpRide for my SC. Like you, I was running into issues with the bottle cage. I did buy a Fidlock which is not a bad suggestion, although the Thule 591/598 still didn't quite like it - couldn't get the clamp perpendicular to the frame on such a long bike. I was buying a second rack anyway so I splurged and went for the UpRide.
It's fine, it works well but it's more fiddly to mount the bike and there's definitely more wobble.
That Inno ^^ looks similar.
Brilliant and doesn’t damage frames unlike the Thule ones that clamp the downtube.
I have clamped my carbon frames for years with this style of rack. No issues. I don't really believe it's a problem with carbon frames and if anything I'd wager a thin aluminium frame is more likely to get damaged. The 598 has broader, softer 'jaws' than the 591 which probably helps a bit too.
Posted : 17/05/2021 12:37 pm
I use a Yakima highroad for my XL hightower with 29" wheels (2.6" front and 2.35" back as I think that makes a little difference); it is pretty much at the upper limit for the rack but we get on without any issues.
https://www.yakima.eu/highroad-black
Posted : 17/05/2021 1:04 pm
Anyone got any recommendations for an V2 XXL hightower? from what I've read everything is too short!
Posted : 19/05/2021 11:34 am
Thule upride Ive used this with a xl Megatower over motorway speeds :~) and would easily take an xxl Again to frame fouling just wheel grabbing
Posted : 19/05/2021 11:59 am
A 598 should take an XXL Hightower, you can adjust where the arm is to fit correctly. My XL Bird Aeris fits in one and must be similar length
Posted : 19/05/2021 1:24 pm
The Inno i mentioned fits a Pipedream Moxie Longer model with almost a 1300mm wheelbase easily.
Posted : 19/05/2021 4:10 pm
