Using SQ taper cran...
[Closed] Using SQ taper cranks with niner bio centric 30
 aP
Is this likely to be a problem? Herself is very interested in buying a niner RLT9 but she uses short cranks and niner don't recommend using non external bearing chainsets with the bio centric. Any suggestions?
Posted : 26/08/2014 1:57 pm
How short? Is 165mm too big?
Posted : 26/08/2014 2:12 pm
 aP
She's got existing 155s from her Madone which got t-boned last Thursday, seems a shame not to use them.
Posted : 26/08/2014 2:14 pm
My guess is that tightening the NDS cup will be trying to pull the sides of the bb apart and might distort it?
Posted : 26/08/2014 2:15 pm
I can imagine that running old-style cup-and-cone bearings might be an issue.
But... oh...ah... but if you think about how a, say, UN51 BB fits in a frame, it's actually by PUSHING the two sides apart. That's no issue in a conventional BB, but when the BB is two seperate halves - that have to be clamped together to clamp in the frame - yeah - I can see that would be a problem.
A square taper BB that has a LOCKRING on the outside, rather than a cup that presses onto the bearing unit should be OK - as that's "pulling"...
Posted : 26/08/2014 2:16 pm
 aP
Thanks brant - something like the spangly TA axis do you reckon?
Posted : 26/08/2014 2:28 pm
I think so... but I'd check with Niner.
Posted : 26/08/2014 2:58 pm
 aP
Update - just had a response to my email, from niner's Director of Fun, that the TA AXIX will work with the Bio-Centric 30 BB.
Posted : 02/09/2014 5:10 pm
