i know this has been asked before and i guessing you'll say "yes, it's fine".
with CRC you now have to select rotors separately, so can i choose the lightest/cheapest/pimpest looking rotors to use with SLX brakes?
does the same go for mount adaptors?
cheers
J
Posted : 13/04/2009 10:14 pm
I use Hope floating sawtooth rotors with my XTR's without problem, they should be fine with SLX.
Posted : 13/04/2009 10:17 pm
The only thing to be aware of is if the pads are wider than the brake track - if this happens the pads run on the spokes as well - no great issue but you will lose a little performance and you [i]might[/i] get judder.
Posted : 13/04/2009 10:24 pm
