Using a workshop st...
[Closed] Using a workshop stand - Whyte T-130
6 Users
This might sound stupid so bear with me please...
I've got a Whyte T-130 and I've no ****ing idea on the best placeto clamp the workshop stand to.
The bike has a 'high level' shock which mounts to the underside of the top tube so I can't clamp to the TT. It also has a Reverb so I can't use the seat post.
Any suggestions?
Posted : 10/09/2016 3:06 pm
Clamp the reverb just put a rag around it
Posted : 10/09/2016 3:07 pm
wiggles - Member
Really? I only have about an inch of the Reverb outer tube showing from my seat tube. Isn't there a chance of bending/deforming the Reverb inner if I clamp there because of the weight of the bike?
Posted : 10/09/2016 3:13 pm
What size frame? I clamp mine on seat tube - not seat post - it fits in the triangle at top seat tube.
Posted : 10/09/2016 3:20 pm
DickBarton - Member
It's a medium. The jaws of my clamp are too big for that triangle at the top of the seat post.
It's a Stealth Reverb too so I can't just swap that out for a regular seat post.
Think I might have to modify the width of the jaws on the clamp.
Posted : 10/09/2016 3:33 pm
So you just lift more of the reverb out of the frame then clamp it. feed some more cable through if needed
Posted : 10/09/2016 3:36 pm
legend - Member
D'oh, yeah, that should work. 😳
Posted : 10/09/2016 3:47 pm
i just clamp the nose of the saddle but its not a fantastic grip so Im quite gentle with it and if I needed to remove a pedal for example I'd probably take it off the stand to get the right pressure.
Posted : 10/09/2016 4:28 pm
Just clamp the Reverb inner. It's stronger than the outer anyway and you won't do any damage as long as you wrap a clean rag or something round it to prevent scratches.
Posted : 10/09/2016 5:51 pm
