Hi all,
I am after some help from the STW hive mind. I`ve just purchased a set of 2011 tapered steerer F120 fox forks for my 2009 stumpy s-works carbon. The problem is that the lower headset bearing cup (integrated type) is very deep so a normal bearing is way to narrow. The cup is about 10-12mm deep, with normal bearings all around 7mm in height.
Has anyone had this problem and if so how did you solve it?!
Ta
Shorts
Posted : 23/09/2010 11:50 am
Picture?
1 1/8 and 1.5" Threadless, Campy style upper with 1.5" lower, cartridge bearings
Posted : 23/09/2010 12:21 pm
Ill see what i can come up with. The bottom bearing seems to have a 45 degree external chamfer on the top too, which doesnt resemble any of the integrated bearings i can find.
Posted : 23/09/2010 12:51 pm
