U-Turn Rebas don�...
[Closed] U-Turn Rebas don't extend to full travel - any idea why?
[#2280241]
They had a proper (TFTuned) service in the summer, and a few weeks ago I dropped the lowers cleaned and put new fork oil in.
I went to check my air pressures last week (which I always do at full 115mm travel) and despite winding them all the way out they don't go much beyond the 100mm ish I normally run them at. I can push them out to 115mm and it feels like I'm creating a vacuum as they then return immediately to around 100mm travel.
They feel ok out on the trail. Possibly a little soft (but this could just be trail / tyre combo). Pressure are being maintained, -ve is about 10psi higher then +ve.
Any bright ideas what might be wrong?
Posted : 13/12/2010 3:47 pm
My mates revelations were staying low a bit like yours and when we let out all the air in the - chamber they popped up to full travel.
Now we set them up by setting sag using the + chamber only and then pumping up the - chamber until they start to compress then letting out a bit of - air which seems to work. They are now working very well for him.
I'd maybe try that?
Posted : 13/12/2010 3:50 pm
That is how I usually fill up the air. But I guess "rebooting" my forks is worth trying.
Posted : 13/12/2010 4:00 pm
Too much -ve air pulling them down.
Let out the -ve, forks extend. Check/set you +ve air, then set the -ve air to the same pressure.
It happens when you've been faffing with the air pressures in the wron order, or adding more -ve then +ve air. Keep the pressures the same, or expect to loose some travel
Posted : 13/12/2010 4:01 pm
Looks like I've probably just made a hash of refilling them after my lowers service then. Amazing how you can be convinced you didn't didn't do something incorrectly despite the glaring truth staring you in the face. 😉
Thanks.
Posted : 13/12/2010 4:37 pm
