Tyre pressure ? (I&...
[Closed] Tyre pressure ? (I'm worse than a roadie I swim and run too)
Ok I'm used to 120psi as normal now on a mtb and loving it, looking at a few off road tri next year. Train mostly at glentress. Still unsure of what's best tyre pressure fore different days / conditions?
Going from trail to mud paths etc?
I'm usually set at 40 psi no but been told to firm. I know tyres are an altogether different subject!
Posted : 28/12/2012 8:17 pm
 J-R
Rooney, see a similar question earlier today.
[url= http://singletrackworld.com/forum/topic/psi ]PSI - Forum topic[/url]
As JoeG implies, you can use lower pressures on tubless becasue there are no worries about pinch flats.
Posted : 29/12/2012 12:24 am
Depends on many factors, your weight, riding style, tyre width etc.
Experiment.
And lower your road tyre pressures.
Posted : 29/12/2012 12:36 am
Yep no real answer something between 20 and 50 depending on tyre setup etc. I used to run low for the superb grip then I learnt how to ride better. Even after going tubeless I still run fairly firm. Last. However pressure should increase as number of spare tubes and distance from home increases
Posted : 29/12/2012 1:29 am
JR
Where does this idea that tubeless equates to no pinch punctures come from? Yes there is no tube to pinch, but if you run tubeless tyres at low pressure and there are rocks you will pinch the tyre. Around here (Northwest) if you go lower than 30 - 35psi in a UST tyre you will wreck it...
T
Posted : 29/12/2012 8:25 am
There is still a perception, from riding road bikes I think, that higher pressures mean faster rolling.
Knobbly tyres run faster and grippier off-road if they can deform to the terrain. That means having the pressure low enough so that they squash as fair bit when you are on the bike. Too low and you will get problems with pinch punctures and squirming in hard corners.
It will vary with tyres, tyre volume, rims, weight and riding speed/style, and terrain.
Posted : 29/12/2012 10:02 am
Around here (Northwest) if you go lower than 30 - 35psi in a UST tyre and you're a clumsy 25 stone oaf you will wreck it...
T
FTFY
Posted : 29/12/2012 10:35 am
No idea what ftfy means, however I do know how many £50 + ust tyres we sell... You keep running them soft, ill keep selling them.
Posted : 29/12/2012 10:41 pm
The difference, as I understand it, between road and off road pressures is the fact that a lower pressure softer tyre distorts to the uneven ground off road causing a lower rolling resistance. On a flat surface(road, towpaths) then a softer tyre will simply increase the contact patch and the rolling resistance.
Posted : 29/12/2012 10:57 pm
15 front 20 rear on tubeless Hans Dampfs on a wide 29er rim. 75kg rider.
Posted : 29/12/2012 11:07 pm
