Two thule 598s, bes...
[Closed] Two thule 598s, best setup for two bikes, flipped or reversed?
 jsm
Hi,
I have two of these going on the car for two bikes side by side.
Did you swap the lock over so it faces out on both sides or run on one bike carrier facing forwards, the other backwards?
if you swap the arm over to the other side the release will be upside down, does that matter?
Thanks,
Stu
Posted : 22/02/2017 9:17 pm
Both bikes forwards; swap the doofer. No it doesn't matter, still works ok.
I always put the first one on back to front though - should mark P&S.
Posted : 22/02/2017 9:19 pm
I tried swapping one of my 591's round so they both pointed forwards. I then swapped it back. Clamp is best fitting from the non-drive side so it can sit behind the chainring. Handlebar clashes are a pain too.
Posted : 22/02/2017 10:06 pm
