tubeless set up hel...
[Closed] tubeless set up help , please!
hello, putting TR HR2 on stans flow, rim set up approp. seals fine and no leaks for 48 hrs (not ridden yet). went up easily with track pump. doesn't seem seated quite right despite no leak and looks symmetrical when looking at side wall but spinning wheel (which is def true) seems to be sl lateral wobble in the shoulder of the tyre. dunno if this will be noticeable riding but going away for w/e so ideally didn't want to find out the hard way?? any thought tubeless diagnosticians??
cheers in advance paul
Posted : 22/05/2014 8:43 pm
Had this with an Ardent. Apparently there is/was a bad batch. Swapped them for some Schwalbes at my lbs and all's been good since.
Posted : 22/05/2014 9:09 pm
Pump em up pretty hard until it 'POPs' onto the rim, the bead of the tyre has to seat into the rim, and needs a fair bit of pressure. Remember to let the tyre down to your intended pressure or you'll be woken up in the night by a big bang. Not happened to me, ever...
Posted : 22/05/2014 9:12 pm
Followed by a lot of complaints when you're a student. Particularly as I was the only person in my house to sleep through this, and it was at the foot of my bed ๐Ÿ˜ณ
Posted : 22/05/2014 9:20 pm
Don't go higher than 40 psi unless you want to be deafened and covered in jizz ๐Ÿ˜ณ
Go and ride it a bit then see if it properly beads
Posted : 22/05/2014 9:23 pm
cheers guys!!
Posted : 22/05/2014 10:22 pm
