I have a set of Ultegra wheels sitting around not being used, (last year's CX pit wheels), so I'm thinking about using them to commute on, however they need new tyres.
Being tubeless ready I was thinking that maybe I'd try it out. So does the forum have a unified opinion on which, if any, work.
Tick
Tubeless on road requires proper road-tubeless tyres, normal tyres fail explosively due to the pressure. Not much choice in tyres tho.
I'm really keen on the idea myself. However, I'm using 19mm rims so I'm waiting for the much promised Hutchinson 28mm Intensive Road Tubeless tyre.
Hutchinson Fusion on Dura Ace tubeless wheels were trouble free for three or four years. No punctures and a really nice ride.
Second ride last night on Conti GP4000S, puncture after 6 miles. I have no idea why I went back to normal tubes clinchers. 🙁
I've used Hutchinson Fusion 2 and 3 and Intensives for the last couple of years on Ultegra and Ksyrium SL wheels.
Only problem I've ever hand is when I cut a Fusion 3 on the sidewall just above the bead and the sealent didn't fix it, but it did patch up and hold air.
I've completed the 160mile Flanders sportive with lots of cobbles on a pair of Intensives, and the Dragon Ride yesterday with a Fusion 3 front and Intensive rear, no problems at all.
Right, so that's two thumbs up for Hutchinson and a "no" for the ghetto route.
Are the Schwalbe ones available yet?
I'm a tubeless user. Currently on 25mm Bonty R3 which are excellent, although they wear faster than the Fusions. Had a glass flint go through on Sat actually, sealant caught it and after a re-inflate was good to go. Impressed.
I have just put a set of Shimano RS61 wheels on my Equilbrium which are tubeless. Looks like a set of Hutchinsons need to be on my shopping list. Ghettoing tyres running at 100psi sounds like a bad idea to me.
You should be able to get ultraremo in tubeless very soon if not right now
But I'm still waiting for my wheels so not tried them
Ultremo ZX are already available from Germany.
Opps slight error in my post , had a rep in just this week flogging them for delivery in very near future
iuse them, I like them, they do feel tub-like, may be psychological tho.
Fusions here and some BNT 25mms for when thy die.
I wonder what problem tubless road is trying to solve?
I really can't remember when I last had a roadie puncture, must have been thousands of miles ago, and maybe 2-3 years? I don't need the lower pressure that tubless allows...
Some things that MTB has developed have transposed to roadie quite happily, tubless doesn't seem like one that springs to mind readily
Then stick to clinchers. I prefer the extra comfort and grip that lower pressures allow.
I've been waiting on the tubeless Ultremos (as above they're available from bike-discount.de now) so hoping to give it a go shortly. The majority of punctures I get are snakebites from potholes so hopefully they should sort that out. Although I'm a fan of normal Ultremos I must admit I'm slightly concerned about using the first gen tubeless version given Schwalbe's incompetence when it comes to QC
Got mine sent over from France (xxcycles). Only had a couple of short spins on them so far but no issues. Fitted with no more faff than usual (on Stans rims).
Off to the Pyrenees next week for some proper test rides 🙂
You are very lucky you don't get punctures. I am currently running heavy horrible feeling Marathons on my commute because I do get punctures and then that then makes me late for work. A puncture finishes your race, waste of race entry money. 🙁
Ignoring punctures, they will roll quicker, feel smoother and grip the road better. That's the theory anyway, would love to try and see if it works. Tyres make a big difference to how a road bike feels in my experience.
Cars don't use tubes and it would make sense since you usually have to through a 50+quid tyre away should you get a puncture.
Would love to go tubeless on the commute, use cx bikes generally - but I guess you need a tubeless friendly wheelset? Running a pair of on-one pikey5000s on the pompino and some touring wheels on me tricross, holding up fine so there's not big motivation to switch wheels. 60 psi though so maybe a homebrewed tubeless affair might be a goer?
Clinchers on wide aero rims are (rather counter intuitively) more aerodynamic than narrower tubs as they present a smoother rim/brake track/tyre surface to the air, whereas a 23mm tub is 23mm and circular regardless of the rim you put it on.
And tubless (should) ride as well if not better than tubs (as tubs are just expensive high TPI/lighweight tyres with latex tubes).
Some excellent info here guys, thanks.
Don't tubeless tyres save the weight of the inner tube?
...and that advantage applies whatever bike you ride 8)
My main reason for sticking with clinchers and tubes, on road or trail, is my perception of reliability with tubeless.
then add some sealant and your back to square one.
not convinced myself.
As for the aero thing, you can prove anything with numbers. headwind, tailwind, cross wind etc. Then how much disturbance do legs make, does the size of the riders calfs influence the aerodynamics of the rear wheel, etc,etc, etc.
I was following a rider on Sunday that hit a pothole, he had a double puncture and a very scary few moments, I hit the same hole with no issues at all, and I'm considerably heavier than him!
The tyres feel fast and comfy, certainly no slower than other tyres I use (ultremos and continue 4000s)
Ok, put it another way, what advantages to tubes have over tubeless?
I took my tyre off to check the sealant levels a few days ago. I removed 3 thorns, one piece of flint and two bits of glass. I'd say that makes them worthwhile. (Hutchison Fusions on Stans Alpha for me)
far wider choice of tyres, ability to swap tyres as and when easy and relatively clean to repair punctures/sidewall tears etc.
As for the puncture thing, one puncture in the last 4000miles, and that was a large nail. And hit a pothole large enough to render the rim unusable but no puncture.
What about tubeless CX tyres?
CAn they be 'ghetto'd'?
DrP
This: http://www.cyclingweekly.co.uk/tech/gear/128654/1/stan-s-notubes-700c-tubeless-system.html
I havent used it on the road yet (only got my bike yesterday but will be converting the non-tubless wheels soon). From experience on MTB, I've found Stans to be the best sealant.
Dont be one of these numpties that on their first puncture gives up. If you've got enough sealant it will seal. If you haven't and the hole is big but not too big, repair with one of these and bimble home or continue your ride (MTB):
http://www.chainreactioncycles.com/Models.aspx?ModelID=7971
If that fails and you have to use a tube then be prepared to faff and remember to check the tyre to remove the dozen or more thorns in the tyre you never new were there!
Also - remember to check sealant levels periodically and top up if you notice any on your frame as you've had a puncture but not had to stop.
I'd also recommend getting yourself some C02 from http://www.co2cartridges.co.uk/index.php?act=viewCat&catId=284
I use these with my inflator chuck thingy http://www.co2cartridges.co.uk/index.php?act=viewProd&productId=256&category=303
And if you want some cheap tubeless tyres to give it a try on, go for these:
If you find tubeless traumatic, it is more likely than not, you are doing it wrong. Google for how to vids. The notubes site is excellent 😉
HTH and have fun
The aero advantage is probably real but definitely insignificant.
Indeed you can. A genuine test would take everything into consideration that you've mentioned.
I'll be doing it 95% for the puncture protection (even though I rarely suffer punctures they're hassle when they happen), the other 5% benefit comes from reduced rolling resistance (no tube friction) and being able to run lower pressures (more comfort).
Is it worth blowing £500 for a new set of wheels & tyres? Not IMO but many rims are already suitable and I need new wheels anyhow so makes sense to get tubeless ones and fork out the £100 on tyres.
Thanks for the info CptnSlow. I'll give this a go at next tyre change time.CaptainSlow - MemberThis: http://www.cyclingweekly.co.uk/tech/gear/128654/1/stan-s-notubes-700c-tubeless-system.html
Just went to get the bike out of the garage for a quick hour. Flat front tyre, two punctures in seven rides back on GP4000Ss (quite unlucky, I accept).
Taking a mountain bike out instead, will order more Fusions when I get home.
I've been using a set of ultegra wheels now on it's third set of hutchinson's on my main training bike. I've had no issues at all with them, one tyre was killed by a chunk of glass but this would have killed any tyre. My trainer is also my roadtrip bike, and has done sub zero work in Norway and blazing hot mountains across Europe.
I don't think I'm getting the most out of tubeless as i still run 23mm tyres and run them hard, as that's how i like them. I still run clinchers on my dura ace race wheels, which i guess i could convert but haven't really felt the need, i can only think of 2 flats in the time i've had the tubless wheels running, and neither were whilst racing. So whilst i have nothing but good things to say about road tubeless ime, they haven't really changed my world.
Don't use CO2, found out the hard way that it for want of a better analogy 'curdles' stans sealent, all the latex solidifies out of the solution.
