Trying to fix a Sra...
[Closed] Trying to fix a Sram chain
7 Users
It snapped and I've run out of powerlinks so I thought I'd push out a pin remove some damaged links and stick in some spare chain links from when it was new thata I kept, can't get it to work. The reconnected links are stiff as a board unless I don't mount the pin properly which is pointless. Is this something Sram chains do or am I missing some kind of trick? Used to do this with Shimano chains no problem. Do I have to use powerlinks??
Posted : 07/04/2010 7:54 pm
how many powerlinks have you got in it? could it be time for a new chain?
Posted : 07/04/2010 7:56 pm
All I can suggest is using the chain tool to push the pins back and forth until the link feels OK
i've joined sram chains before no problem, try giving the chain a sideways wiggle sometimes works for me
Posted : 07/04/2010 7:57 pm
I've been at it half an hour now, sod this!!
Posted : 07/04/2010 8:00 pm
Best way to fix a SRAM chain is to remove powerlink, replace with KMC or high end Shimano equivalent, re-fit powerlink... voila! fixed.
Posted : 07/04/2010 8:05 pm
Sideways wiggle worked hooray and thanks. Saved me 30 quid.
J
Posted : 07/04/2010 8:23 pm
JB - Was gonna second the sideways wiggle but sounds like you've sorted it!
Posted : 07/04/2010 8:24 pm
Saved me 30 quid.
ding f*** dong!!
where the hell do you shop?
Posted : 07/04/2010 8:32 pm
need a chain for tomorrow so would have to go to mountain trax same chain 30 bhatt
Posted : 07/04/2010 8:34 pm
