Truvativ noir crank...
[Closed] Truvativ noir cranks - threaded sleeve for pedal has come loose
So the metal insert that you thread the pedal into has started wobbling.
Is it crank replacement time or is there a tried and tested solution (aryldite my simple bodgetastic mind is thinking)
Posted : 20/03/2015 7:38 pm
Cheeky Saturday bump...saw another thread mentioning epoxy in the sleeve back in unless someone wants to tell me it,s just not going to work
Posted : 21/03/2015 10:19 am
Araldite was recommended on a similar thread about a bottom bracket insert
Posted : 21/03/2015 10:29 am
Cheers. Just got crank arm off and it's going to be tricky to get the epoxy in there. Looks like there is a lip at the front on the carbon so drifting it out that way looks out. Suspect it was inserted from the back as there's a plastic ring stating crank size, but not sure if that will come out easily
Posted : 21/03/2015 10:42 am
