on the front with a Spyre set up the inner part of the actuator arm, where it pivots at the bottom, is brushing the spokes. Anyone come across this problem before?
Posted : 03/07/2017 8:41 pm
You could try a rotor shim to move it outboard slightly or a larger rotor.
Posted : 03/07/2017 8:45 pm
Yes - I moved the rotor outward using some thin spacers.
Posted : 03/07/2017 10:34 pm
thanks both - spacers it is.
Posted : 03/07/2017 10:40 pm
That happened to me before. Turned out the dish of the wheel was wrong. A friendly LBS Redisham it for me for free and it was fine
Posted : 04/07/2017 8:33 am
I think I also had to shim mine to get the alignment right.
Posted : 04/07/2017 9:05 am
Blimey, the dish must have been *way* out if it went from fouling the caliper to a safe margin…
(Spacers here, too.)
Posted : 04/07/2017 10:51 am
