Trek 2013 remedy ma...
[Closed] Trek 2013 remedy maxle setup / 2009
Hi all
So I got a new frame 2013 remedy which is set-up for 142x12 maxle.
but need to use my old skewer & wheel from my 2009 remedy which I think is 135mm set-up
Anyone know if I get the trek abp convert kit it will work ?
http://www.pedalon.co.uk/acatalog/trek_abp_convert_135_x_5_hardware.html#aTC8756
Posted : 28/12/2012 1:08 pm
Trek might send you the bits if you ask them given your trying to use your original set up? You might also be able to convert the hub but if I remember correctly the axle price costs more than the conversion kit!
Posted : 28/12/2012 5:09 pm
You should get both 9mm QR and 12mm maxle parts with the frame. I did with mine. You just replace the dropout etc for whatever you're using.
Posted : 28/12/2012 5:25 pm
