2012 model 30.9mm 125 drop and 420 length?
168 quid from bike- discount.de. about the best you will find.
Cheers pitch but the specific one I'm after on there site is 289 euros
Merlin were/are doing some good deals. I went went with the same spec as you but the 100mm drop for £150 including bleed kit a month or so ago. Couldn't justify the extra £80/100 extra for 25mm. You can get the 100, 420, 30.9mm version for £170 at the moment. You can drop the seat manually by an inch or so for the really steep stuff. Also, better to buy the opposite side lever to what you want and run it under the bars. More comfortable and less prone to damage.
€239, including bleed kit: http://www.bike-components.de/products/info/p29471_Reverb-125mm-Sattelstuetze-mit-Remote-Matchmaker-rechts-.html
