Travel adjust on Re...
[Closed] Travel adjust on Rebas...
[#711483]
I'm looking on the flea-bay at the moment for a set of Rebas (idealy the 'team' model, in silver). Are all the various variants from say, 2006-2008 travel adjustable?
...And is the adjustable travel range the same on each model?
I'd be looking to run them in the range 80 - 100mm (ideally 80mm), but some of the ones I've seen say they are 110-115mm travel, or something like that.. Would I be able to reduce the travel on these ones to 80mm?
Confusing..
Cheers!
Posted : 16/07/2009 8:24 am
Yes. You have to strip the air cartridge and add a spacer to reduce the travel. All Rebas can be done like this.
Posted : 16/07/2009 8:41 am
You don't even have to remove the lowers / air cartridge.
- Let all the air out of both chambers.
- undo the top cap - 24mm socket.
- undo the 5mm allen bolt in the bottom of the LH leg.
- compress the fork (catch the oil out of top & bottom).
- slot a spacer in on the shaft.
- put back together.
- simplez.
Posted : 16/07/2009 9:35 am
Steve, that's a good way of doing it! Nice tip I think!
Posted : 16/07/2009 9:39 am
that is a good tip,
does that work for increasing travel, ie do they all go up to 115, if mine are 100mm will there be a spacer to remove to go to 115?
Posted : 16/07/2009 9:45 am
no_eyed_deer drop us a mail might have some 2007 reba races in a day or so?
laura.pell1@ntlworld.com
Posted : 16/07/2009 9:47 am
Cheers for the info..! but, sorry to be pedantic, just to clarify - do ALL Rebas go down to 80mm?
@ timdrayton - I'll send you an email..!
Posted : 16/07/2009 10:38 am
tim, iirc there will be a 15mm spacer in your fork (behind the topout bumper) that you remove: this lets the fork extend to 115mm then.
The sram service guide pretty much explains it all.
edit: no reason why any (normal not air u-turn) reba couldn't go down to 80mm if you put another 20mm spacer in.
Posted : 16/07/2009 10:40 am
Pre '09 rebas: 85/100/115mm
09: 80/100/120mm
All adjusted with spacers (unless they are a u-turn model).
Posted : 16/07/2009 10:55 am
