Im about to order a wheelset for my new Heckler, i was going to order some EN321's on Hope evo's
are the EN321's a good choice, im pretty green on wheels so any advice on other options are welcome.
Very tough,not very light,classic light wide rim is now Stans Flow,which are a fair bit lighter.
Ian
hope pros on whatever stans rim best suits you and your riding.
Yup I'd vote for Flows too, EN321's are tough as hell but slightly lardy into the bargain
They're 110gms heavier than the Flow.
Also,the Stans make it easier to go tubeless,if that floats your boat.Look at the Justridingalong site for options,you may get them built cheaper,but quality counts.
happy with my Hope Hoops pro 2 on Mavic EN521s good strong wheels and not too heavy either; have stayed true for 1000 miles XC / trail centre riding 🙂
I should have probably said that i only have £270 to spend.
Wouldn't worry too much about the weight difference. I've had/got both: weighed on the same digital scales...
Hope Pro2 with Flow Rear: 997g
Hope Pro2 with 321 Rear: 1090g
If you're going tubeless then the Flow but other than that, it's whatever is available imo
Here you go,Hope hoops ,Hope pro 2 on Flows,£279,and a nice guy to do business with,he's my LBS.
Very impressed with my new Flow rims. Light and strong, have them on my Meta 5 and they take fast Peak descents in their stride. Spent last night clobbering them down the DH tracks in Wharncliffe with no problems so chuffed so far with my first non Mavic rims for years. Pretty light for the strength. No eyelets though.
Cheapest in can find Stans Flow is Evil-bay, are they right for me?
Stans arch are slightly narrower and lighter, but flows are pretty similar.
I ran hope \ 521s for years (bought them off gravity slave funnily enough). they are still as true as the day I got them. Moving to hope \ flow has transformed the bike though, they feel lots lighter. I'm surprised at how little weight difference nuke found but then I guess tubeless saves another ~100g per wheel?
And I'm clumsy as all hell but the stans seem to hold up fine, even when I crash at wharnecliffe
So the E-bay hoop are good valve at £285?
it's the en521 for me. great strength for the weight,strong enough even for downhill. half the price of flow rims as well.
Another recommend for the Flows, though since you've told us nothing about your riding that's really just a guess. Good chance you could go lighter, very little chance at all that you need to go heavier.
jamesb - Memberhappy with my Hope Hoops pro 2 on Mavic EN521s good strong wheels and not too heavy either; have stayed true for 1000 miles XC / trail centre riding
Well you'd hope so really! Considering the sort of purpose those rims are designed for, they should barely even notice a year of that kind of use.
where can i buy rear derailler hanger for vitus hell?
Another recommend for the Flows though since you've told us nothing about your riding that's really just a guess. Good chance you could go lighter, very little chance at all that you need to go heavier.
I like it ride pretty hard, my bike will be used for everthing from cyclepaths to the alps, i decided to buy the flows (hopehoops) after all the good feedback + the reviews are ace. Thanks for you help guys cant wait to try them.
You're not likely to be disappointed... When you see the use they get, Rowan Sorrell on his everyday bikes, Sabrina Jonnier for racing, knobbers like me riding downhill trails badly on short travel bikes... They do the job 😉
if you get a proper tubeless ready tyre you can run them tubeless with just the yellow tape, dont let anyone go telling you that you need a rimstrip
Im diggin my Eskar's at the moment, may give it a try as there tubeless ready.
I got some Eskars on a pitch, they seemed really good, never tried them tubeless though. Bonty or Maxxis seem to sit nicely on flow
The pitch was where i got on the Eskar tip, whan they wear very well and i never had problem with grip, my riding buddy has some XR4's? on his Remedy and loves them, other mates swear by High rollers so i may try some to see what the hype is about. I have never tried to set up tubeless so i will probably go see Stu at dales and get him to set me up first time.
Hope Pro 2/Mav 819
loads of people on here will give you advice about going tubeless when you are ready to give it a try. Sometimes its dead easy if the tyre fits well. It would be worth you getting the stans yellow rim tape (the wider one for flow) and the olympic valve on order if you want to give it a go. Sometimes they just go up with a track pump
