so building up my workshop at the moment and would like ideas to store my tools, I don't have a lot of space and would prefer them to be easily accessible so wall mounted is an option..anyone have any good ideas on ways to go about it?
b&q do a full wall mountable tool bord with lots of mounts and holes i mounted mine to a large sheet of mdf so can be moved anywhare as we rent not own house.
ooh will go check that,,cheers
liking the bits of angle with holes drilled for the drivers...
best solution I have ever found (this is being a professional bike wrench at different shops)
1" backboard mounted on rawl-plugs and screws into your wall
then use nails and screws to accomodate your tools...think logically about which tools you need the most access to when laying out your mountings
here's the first setup
later setup - painted the Ply black and used silver marker pen to outline all the tools which makes it easier to put them back in place
looking good, was thinking about the outline thing as you say it'll make putting everything back easier (plus the mrs can't go rearranging things then!)
