token pressfit bb
[Closed] token pressfit bb
4 Users
 robd
Some technical help required! I have installed an on one token press fit bb into a frame however my old ht2 shimano cranks only fit through one side of the bb. Is this me being dumb or is it that the bb is faulty?
Any info appreciated.
Posted : 05/10/2013 4:03 pm
If you try the axle from the other side does it physically fit through the hole?
Measure the outside distance across New and old bb's and see if they are the same?
Posted : 05/10/2013 4:06 pm
 robd
Doesn't physically fit, about a 2mm difference in diameter of the hole the spindle is supposed to go through.
Posted : 05/10/2013 4:17 pm
Have you left the GXP washer inside the inner race?
Posted : 05/10/2013 4:21 pm
your gonna need to take it off again - GXP washer is still on!
thankfully I noticed it before fitting it 😉
Posted : 05/10/2013 4:57 pm
 robd
Yep correct indeed, all sorted. Thanks for help.
Posted : 05/10/2013 5:45 pm
