Titus Fireline Ti 2...
[Closed] Titus Fireline Ti 29 Evo..
I have checked the brochure. So much new information for me. 🙂
So if I go for these one:
[url= http://www.chainreactioncycles.com/bg/en/hope-pick-n-mix-headsets-bottom-cup/rp-prod70727 ] headset [/url] I should select:
1. Upper headset option 2
2. Lower headset option D
Am I right ?
Posted : 15/12/2013 8:48 pm
No, [url= http://www.ukbikestore.co.uk/product/24/hsc_lower/hope-pick-n-mix-lower-headset-cups.html ]Lower cup F[/url] EC49 - External, 49mm
and
[url= http://www.ukbikestore.co.uk/product/24/hsc_upper/hope-pick-n-mix-upper-headset-cups.html ]Upper Cup 2[/url] ZS44 - Zero Stack, 44mm
Posted : 15/12/2013 10:06 pm
If you have a straight steerer and if you wanted a lower stack height you could go for a ZS49 as your head tube should accommodate it. Otherwise with a straight steerer and F/EC49 you'd also need the HS136 reducer.
However if you have a tapered steerer it's as dantsw13 says.
Posted : 16/12/2013 11:36 am
Also the Geometry is designed around a 15mm External Cup, so if you used a Zero Stack Lower Cup, the front end would be lower, and the HA steeper.
Posted : 16/12/2013 11:39 am
My loud, sorry for the delay
My bottom bracket on the large is 12 inches centre to floor
Lester
Posted : 16/12/2013 5:26 pm
Ive just ordered forks/wheels/reverb, so hopefully get mine built before xmas!!
She is waiting for me in my workshop!
[img][url= http://farm4.staticflickr.com/3711/11404873903_763614ac25.jp g" target="_blank">http://farm4.staticflickr.com/3711/11404873903_763614ac25.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/76248110@N06/11404873903/ ]Untitled[/url] by [url= http://www.flickr.com/people/76248110@N06/ ]danthomassw13[/url], on Flickr[/img]
Posted : 16/12/2013 5:39 pm
Nice. Workshop looks far too organised 🙂
Posted : 16/12/2013 6:23 pm
Only from that angle!!! I have actually just had an early "Spring Clean" in preparation for my new build!!
[img][url= http://farm3.staticflickr.com/2853/11406530456_c331c0df46.jp g" target="_blank">http://farm3.staticflickr.com/2853/11406530456_c331c0df46.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/76248110@N06/11406530456/ ]Untitled[/url] by [url= http://www.flickr.com/people/76248110@N06/ ]danthomassw13[/url], on Flickr[/img]
[img][url= http://farm8.staticflickr.com/7362/11406651033_b51b326df8.jp g" target="_blank">http://farm8.staticflickr.com/7362/11406651033_b51b326df8.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/76248110@N06/11406651033/ ]Untitled[/url] by [url= http://www.flickr.com/people/76248110@N06/ ]danthomassw13[/url], on Flickr[/img]
Posted : 16/12/2013 7:49 pm
Mine purchased too from the on - one site. I am planning a build with this fork:
[url= http://www.chainreactioncycles.com/bg/en/rockshox-sid-rct3-solo-air-forks-15mm-2014/rp-prod109680 ]fork[/url]
First I will ask the guys from CRC for its a2c length.
In the on - one site is written best result a2c - 526mm
Posted : 19/12/2013 5:18 pm
If you can get them in 120 then they should have a 526 a2c.
Specs are all [url= http://www.sram.com/service/include-archived/rockshox/7,102,438 ]here on the SRAM website[/url]. Curiously they don't show the 120mm, but all the other 29er 120mm forks are 526, and the 100mm SID is 506, so assume the SID would be no different.
Edit...
Looking at the RockShox range I'm really not sure what I'd go for. You could go SID, Reba, Rev, or possibly a Pike on this frame (think there are examples of all here.) Seems to be a lot more overlap with their 29er forks.
Posted : 19/12/2013 5:32 pm
Reba looks fine. I have one reba here. It has been extended from 100 mm to 120 mm with removing a spacer ( well actually it has extended to 110 mm ). I have measured its a2c and it is 530 right now. 🙂 Unfortunatelly I am not sure if my steer will be long enough. According to my measurements it is quite on the edge. If it fits I will reuse it, but if not I will go for the SID.
I have one more question. Does anybody know what is the height of hopes lower EC49 - External cup ? ( F option from this link ):
[url= http://www.ukbikestore.co.uk/product/24/hsc_lower/hope-pick-n-mix-lower-headset-cups.html ]F cup[/url]
I have looked on hopes website for some info, but did not found.
Posted : 19/12/2013 6:32 pm
Their conventional headset has a lower stack height of 14.1 mm and I'd assume that the 1.5 wouldn't be far that.
Posted : 20/12/2013 1:37 pm
Many thanks for usefull information. I will post fotos with my build, when it is done. I am planning it for middle february to be fully complete.
Posted : 20/12/2013 5:21 pm
Looking for some fit/sizing advice! Is anybody 175cm tall on a medium/18"? What size fireline is closest to a medium canfield?
I've previously owned a medium canfield yelli screamy, and currently have a 16"/small Kona Honzo. The Honzo is a little small, the canfield was just about right. Comparing the geometry charts between these bikes makes me think the fireline reach or top tube lengths are incorrect- either that or the reach is extremely short despite a steep seat angle and decent top tube length? Furthering my confusion is Brant's recommendation for a size small at my height- on paper that's smaller than my Kona (which is smaller than I'd like for longer rides, having owned ridden it for a year now). The 18" fireline looks pretty close to the medium yelli screamy, which is why I'm leaning that way. Only the head tube length worries me on the 18" fireline.
I'm 175cm tall, my saddle height is 74cm from center of BB to top of saddle. 760/20mm bars and 50mm stems on all my bikes.
Here's some numbers from the geometry charts- note the reach #'s vs TT lengths-wtf
Reach
Titus Fireline Evo 29 18": 15.3"
Canfield Yelli Screamy Med: 16.18" / 411mm
Kona Honzo 16" : 16" / 406mm
Top tube length
Titus Fireline Evo 29 18": 23.6"
Canfield Yelli Screamy Med: 23.75" /564mm
Kona Honzo 16" : 23" / 584mm
Head tube:
Titus Fireline Evo 29 18": 4.7" / 120mm
Canfield Yelli Screamy Med: 4.3 / 110mm
Kona Honzo 16" : 3.5" / 89mm
By the way, I've also posted on MTBR.
Appreciate any thoughts.
Posted : 23/12/2013 12:31 am
I'm not up on reach and stack, I ride a medium Yelli and am looking at the Fireline too. I'm a tad shorter than you, height is a very rough benchmark for bike fit though I think.
ETT on a medium Yelli is 23.75 inches, and 23.7(0?) on a Fireline 18".
I'd buy the 18" for myself, especially since I like running a short stem.
What's concerning you re the head tube?
Posted : 23/12/2013 9:38 am
Ah so the top of the HT is going to be about 10mm higher on the Fireline than your Yelli, is that right? As long as you had at least 10mm of height you could lose from your Yelli by taking spacers out or running flat bars or flipping the stem, I think you'd be OK.
ps it's just possible I've ruined my Yelli frame with mechanical incompetence, I'd buy another if they weren't so damned expensive in the UK. Is that your thought process too?
pps selling your Honzo?
Posted : 23/12/2013 9:40 am
Thanks Matt, thats encouraging.
I've grown to trust reach/stack more than ST/TT length, since it removes seat angle from the equation.... and seat angle is funky on a lot of these 29'ers. But supposedly it's 73 on both the yelli and FLE, so maybe the 18 FLE would fit like a medium YS. I'm just hoping to avoid any surprises since there's no possibility of a test ride... and the fireline reach numbers seem off.
Based off the planet-x fit chart, height puts me on a 16, inseam puts me on an 18. If I could go custom I'd split the difference, as I know 17"ST/23.25" ETT is perfect for me. You're right about the bars, I could just run flat bars to get them lower.
I am in the states, not much info on the fireline over here. Yes, the honzo will go up for sale, it's super fun but a little small and a little stiff&heavy for me. Looking for more epic-xc friendly ride. The yelli was perfect and the fireline looks promising!
what'd you do to your YS? BB or headtube damage?
Posted : 23/12/2013 12:53 pm
It's really just the geometry charts posted that have me second guessing.
The reach numbers are 1"+ shorter than other similar bikes with comparable top tube lengths.
Also noticed the static geometry lists the same head tube length for 16 & 18" frames, while the "ride height"geometry shows them as being .4" different. Looking at photos the 18" def has a taller head tube.
Posted : 23/12/2013 1:07 pm
Fireline Evo stats...
16in has 110mm head tube
18in has 120mm head tube
20in has 125mm head tube
Seat angle is 72deg static.
Posted : 23/12/2013 1:13 pm
Ah you're in the US, to be honest if I could pay US price for a Yelli I'd probably just buy another (import duty and tax means they come out more like the equivalent of nearly 1400 USD bought in the UK, the FLE is cheaper).
A loose chainring bolt gouged about 1.5mm out of the chain stay plate on my Yelli, I have an email into Canfield to see what they say, no response yet but it was only yesterday, mail if you want a pic (mail in profile).
I like the flat bars, I find rolling them forwards a couple of degrees increases comfort a lot.
Sizing's always a bit of a punt for sure, I'm not an FLE owner so can't give an answer from experience. If I get to ride one I'll let you know.
Posted : 23/12/2013 1:14 pm
Thanks Brant. Do you reckon I'd be OK on the 18"?
By the way- regarding my small kona honzo- the reach is OK, 16" seat tube is pretty short for my saddle height, but I find the wheelbase a bit short for higher speed rough trails. That is part of why I am leery of going too small again.
Posted : 23/12/2013 1:20 pm
For a fun trail bike I'd go for a 16in. If you want something a bit more steady, then the 18in would be OK.
Posted : 23/12/2013 3:02 pm
Thank you Brant
Posted : 23/12/2013 6:27 pm
yay Canfield say my Yelli is sound. Purchase of titanium goodness postponed, and daughter's pocket money is safe for another year.
Posted : 23/12/2013 8:42 pm
Any of your guys know the total weight on a Fireline built by on-one ?
Posted : 23/12/2013 10:25 pm
follow up... michael at Titus/ Planet-X USA was super helpful today and took some measurements for me. Basically confirmed the 18" is the size I am looking for (it's actually got a similar front-center/reach to my small kona honzo) so the 16" fireline would be shorter than I am looking for.
Posted : 24/12/2013 2:22 am
good news, are you going to order? (& does it differ much from a M Yelli?)
Posted : 24/12/2013 9:26 am
Yep, ordered last night (happy holidays to me LOL).
I had michael measure from the center of the BB to the center of the head tubes bottom edge. The 16" fireline came up 1" shorter than my small Kona Honzo. The 18" fireline came in with the same number as my other medium/17" banshee 29, which fits perfect. Of course this isn't a great way to measure front-center but it gave me the info I was looking for.
Ill post a pic up after the holidays, when I get 'er built!
Posted : 24/12/2013 5:28 pm
Im having a bit of a brake adapter faff.
What adapter for a 180 rotor on the rear with a PM brake?
Posted : 29/12/2013 3:40 pm
Crap photos, but finally built!
[img][url= http://farm6.staticflickr.com/5521/11672818994_9c4c965109.jp g" target="_blank">http://farm6.staticflickr.com/5521/11672818994_9c4c965109.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/76248110@N06/11672818994/ ]Untitled[/url] by [url= http://www.flickr.com/people/76248110@N06/ ]danthomassw13[/url], on Flickr[/img]
Posted : 31/12/2013 8:03 pm
And finally ready to ride.
[img][url= http://farm8.staticflickr.com/7330/11818842846_b8e27d0c24.jp g" target="_blank">http://farm8.staticflickr.com/7330/11818842846_b8e27d0c24.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/76248110@N06/11818842846/ ]Untitled[/url] by [url= http://www.flickr.com/people/76248110@N06/ ]danthomassw13[/url], on Flickr[/img]
I wasn't happy with the tyre clearance from the cable with a conventional mech, so I got the Direct Mount Clamp from On-One and went full length outer cable to a Direct mount front mech.
Only a road test so far - first ride tonight!!
Posted : 07/01/2014 3:06 pm
Awesome work you'll love it!
Posted : 07/01/2014 4:45 pm
Well, first ride done!! Possibly the wettest, muddiest, boggiest ride I've ever had, but the bike performed admirably!! Plenty of traction, front end tracked as well as could be hoped for in the conditions, fork worked really nicely.
It is my first 29er, and my first Ti bike, and its a combo that I like!! It really felt like a half way house between a HT and a FS, with the Ti frame taking the edge off the rear end bumps.
No mud clearance issues at all, although its so wet out there, I expect it to be more of an issue as the ground dries out a little (If it ever does!!);.
Posted : 07/01/2014 11:13 pm
Just got one after the recent discounts. Seat tube seems a little baggy with the post knocking slightly unless clamp cranked tight. I seem to remember this being mention before :-S
Sugnificant issue or potential fixes?
It's with an SDG I beam post.
Posted : 08/01/2014 1:14 am
good looking bike Dan, ride it hard
Posted : 08/01/2014 1:24 am
Mine's built up, I've got a few rides in and I'm super happy.
No fit or quality issues, frame was as good as I could have hoped for.
[url= http://forums.mtbr.com/29er-bikes/titus-fireline-evo-29-review-894036.html#post10918098 ]Full review here[/url]
Posted : 08/01/2014 5:06 am
The baggy seat tubes were only supposed to be an issue on the earlier batch, so I'd be returning it. Mine is nice and tight on 2 different seatposts.
You are using a 30.6 post???????
Posted : 08/01/2014 10:39 am
Thanks for the write up, I'm a medium Yelli rider too.
Do you not notice the slightly longer chainstays of the Fireline? That's my major concern in moving away from the Yelli.
Posted : 08/01/2014 11:02 am
Im pretty sure the only reason the Yelli has longer chain stays is the more relaxed seat tube, and the fact that the bb is behind the seat tube/downtube junction.
Given the tight clearance on the Fireline, the actual distance from the bb to rear axle is as short as you can get. It manuals easily, and is very manoeuvrable.
Posted : 08/01/2014 11:20 am
Yeah maybe, not all measurements are like for like.
Posted : 08/01/2014 11:52 am
Yelli, Honzo, Zealous Division etc all have significantly shorter chain stays than the Fireline. Offset (Yelli) Curved (Honzo) and split (Division) seat tube accommodates the short stays.
Fireline is tight for clearance maybe, but short - no.
Posted : 08/01/2014 12:00 pm
depends how they're measured.
some companies just measure the length of the chainstay.
some companies measure the horizontal distance between the BB and the rear axle, and then state this as the 'chainstay length' - it's cheating a little, and it makes a frame sound more fashionable.
the titus is measured the honest way, 17.1"/434mm is pretty bloody short.
of course bikes are available with shorter chainstays, but crossing the fireline off your list for it's 'long chainstays' is a bit daft.
Posted : 08/01/2014 12:18 pm
but with regards to handling it's probably the dimension that matters, i.e. "effective chainstay" rather than "actual chain stay".
Yelli is quoted as 424 "effective", Fireline is 434mm "actual" so would be a few mm less effective, I've forgotten the sin/cosin maths I learnt at school to work it out.
But I suppose I could just measure my Yelli! So I did that, I'd agree with the 424mm effective and maybe 427mm actual, give or take a mm or 2.
Posted : 08/01/2014 12:32 pm
Honzo 415mm actual
Division 419m actual
Looks like Yelli figures may be horizontal (I'll measure my mate's…)
Genesis High Latitude and Fortitude have 435mm actual c/stay length.
All the above have significantly lower BB's too.
Fireline is a but ho-hum. tall BB, tall headtube, short front centres (relative to all the above). For something that wants to be seen as new school, seems to me it's very much not.
Added to that the questionable build quality and the Planet X factor - it's never going to be on my shopping list.
Posted : 08/01/2014 12:35 pm
Yes http://canfieldbrothers.com/frames/yelli-screamy
No need I measured mine, see ^^, 120mm fork unweighted.
Posted : 08/01/2014 12:40 pm
Page 19 / 22
