What are people running? used SPDs and Crank Bro's before, any preference?
Oh these are going to be used on my commuter.
i have used time pedals for years and only ever used them with the G cleat on the left. i think that's 13 deg.
I dont know if i could twist my feet enough to get out with the increased angle!
the 'race' setting does require quite an extreme twist to release.. but is super attached.
for commuter i use single side SPD:
[img]
[/img]
though I use Time atac on mtb..i prefer them to SPD might try the single sided commuter version:
http://www.chainreactioncycles.com/Models.aspx?ModelID=52364
G as in gauche, the right one being D as in droite [bloody French ๐ ]
I have some cleats with a star on which IIRC - if you put that on the right it gives you the least amount of float
I tried both in the end and TBH my hips / legs / ankles don't twist well enough to use the 17 degree setting. 13 seems plenty.
I went for the Roc Atac's as I had some one sided ones and struggled to clip in quickly and my route to work involves one very busy roundabout and I could get the speed away if I end up uncliping.
I always liked my Crank Bro's ones I used to run on my MTB but didn't like the build quality. So I thought why not get the Atac's, then when I want to run them on my MTB as well I can.
Thanks for the comments.
