Ti frame. alloy sea...
[Closed] Ti frame. alloy seatpost issue
Hi
I have an old TI bike with an alloy seatpost. The issue is the seatpost is both hard to move in the frame when I want to and also slips when I sit on it.
Now the slipping may be down to a poor clamp but I would like to lube the post as I do adjust it and its a struggle to do so
What would be the suggested lube> Ordinary grease / coppaslip / something else?
Ta
Posted : 06/10/2010 2:49 pm
Hi,
Make sure the seatpost clamp is facing the right way and is actually closing the split in the frame when fastened. Use a strong clamp, Hope with allen key bolt I find is the best for a really strong hold. Use standard grease and grease the frame and then push in the seatpost and tighten up well.
I hope this works!
Posted : 06/10/2010 8:14 pm
I forgot to state the obvious! Make sure you are using the correct stem size for your frame. 27.2mm 30.mm etc etc.
Posted : 06/10/2010 8:17 pm
May be wrong but copperslip is not recommended because of a electrolitic action" Corrosion"
Posted : 06/10/2010 8:18 pm
pace grease stuff, like the stuff below works for me
http://shop.18bikes.co.uk/products.php?plid=m12b8s420p209
Posted : 06/10/2010 8:19 pm
 nonk
finish line do a thing called Ti prep specifically for this.
mind you it may well be costly copper slip,i dont kknow.
Posted : 06/10/2010 8:26 pm
Finish Line Ti Prep = Coppaslip.
The manufacturers story is that it is designed specifically to stop Ti bonding to other metals, but someone on here believes it actually accelerates this process.
Posted : 06/10/2010 10:22 pm
Copper grease/ coppa slip (intended for hot parts / high temperature service) is considered old fashioned even for the original purpose of brake calipers.
http://www.mintex.co.uk/en/products-mainmenu-29/product-overview-gg-mainmenu-38/cera-tec-mainmenu-36
Posted : 07/10/2010 10:48 am
th epace carbon paste is pretty good for both allowing movement and keeping stuff still when you get it where you want it.
Ragley/Nuke Proof do a 27.3 seatpost if you do feel that there's a bit of space and it's a 27.2 post you use.
Posted : 07/10/2010 10:52 am
