Threadlock for slid...
[Closed] Threadlock for sliding dropouts?
About to start the assembly of a sliding dropout build and read somewhere that that threadlock should be used.
I've not used it before on sliding dropouts (Pipedream Sirius) but this time feel I should give it a try ..... ๐Ÿ™„ ๐Ÿ˜†
So .....
Which stuff do I need?
Posted : 09/05/2011 10:14 am
 Del
threadlock or grease? one or the other. ๐Ÿ˜€
222 or something similar will be fine.
Posted : 09/05/2011 1:27 pm
It's torque/tension that holds them and stops slipping - grease will help and be easier to adjust than loctite.
Posted : 09/05/2011 1:45 pm
grease the threads to stop them seizing and get some nord-lock washers to stop the bolts loosening.
Posted : 09/05/2011 1:53 pm
Cheers folks ๐Ÿ™‚
Will look into getting some nord-lock washers now 8)
Posted : 09/05/2011 1:59 pm
 PJay
I just used standard blue threadlock on mine to stop them loosening; I just want them to stay put for a geared setup.
The blue threadlock should be breakable should I need to move/change them at anytime. If you want to slide them regularly though I'd imagine that threadlock's not the best idea.
Posted : 09/05/2011 2:22 pm
I found the best technique was to use grease and then the following:
Tighten the adjusters to get the dropout in the right place
Tighten the side bolts that are supposed to hold the dropout in place
Re-tighten the adjusters so that they press into the dropout a little
Don't overdo step 3, but it does really help to stop them from rattling loose.
Posted : 09/05/2011 3:36 pm
