That air loss sound...
[Closed] That air loss sound when removing a shock pump?
Is it air in the pump or air escaping from the valve/chamber you can normally hear?
If I put 200psi in the boost valve on my DHX5 and remove the pump I hear that air loss sound. If i put the pump back on the pressure has dropped by about 40psi. It's a rockshox pump that I use.
Any thoughts. Cheers.
Posted : 02/06/2009 1:45 pm
Don't worry. It's just the air in the pump/tube escaping.
When you reattach the pump you let air out of the shock into the tube. It was 200psi before you tried to measure it.
Posted : 02/06/2009 1:48 pm
Nice one - That had never occured to me. Thanks for the reasurance.
Posted : 02/06/2009 1:50 pm
its just the air from the pump.
when you plug the pump back in the reduction in pressure is attributable to the pump. Dont woory!
Posted : 02/06/2009 2:05 pm
Depends on your pump, I've seen cheap ones that leaked before the valve was shut. A decent pump should have a double-acting collar that first screws onto the valve, THEN actuates the valve with a second threaded section, in reverse the valve is closed with equal pressure either side, then the excess in the tubing is released with the final section coming off.
Posted : 02/06/2009 2:24 pm
I've had shocks that were difficult to inflate and found that putting a dab of grease on the valve and the thread made a difference. Not sure if it was the pump or the shock.
Posted : 02/06/2009 2:54 pm
