Teeny little brake ...
[Closed] Teeny little brake part - Elixir CR - do I need it?!
Somehow my pad spring twisted itself into the pads/rotors this morning and made a horrible noise. After much faffing, I replaced the pads and spring but the tiny little split ring that holds the pad retainer bolt was wrecked and pinged off into somewhere unknown.
Do I need this bit? Anywhere I can get one? Seems like it's just a "back up" safety measure but I guess it's better to be safe.
And I simply cannot find anywhere that sells them! Any ideas?!
Posted : 26/11/2010 12:15 pm
 fbk
I'd agree - I think they're a bit 'belt & braces' as I can't see how the bolt would unscrew. Having said that, I'd probably try and find a replacement if it were me 🙂
Posted : 26/11/2010 12:21 pm
Trheadlock on the bolt or a wee blob of silicon on the end to stop it unscrewing should it come loose??
Posted : 26/11/2010 12:24 pm
That happened to mine too. I thought I better get it sorted so ordered them from the link below, It also happens to be my LBS and the only place in the country I could find them at the time. I managed to coincide loosing the little ring with rounding off the allen head so I really had to get it sorted.
http://www.bikechase.co.uk/index.php?p=188937
Posted : 26/11/2010 12:28 pm
L Ache - nice one. Not sure if it's me being tight - £5 is fine but £2.50 for delivery hurts! Will see if my LBS does them. If not I'll bite the bullet and buy those. Cheers!
Posted : 26/11/2010 12:31 pm
You're in Truro right, Halfords will keep packs of those little spring clips, just hope they have ones small enough.....
Posted : 26/11/2010 12:33 pm
Called my LBS - they have them and they cost 20p each. Ideal!
Posted : 26/11/2010 12:39 pm
Just get a bit of wire/thin paperclip and push it through the hole and wind it around - works the same 🙂
Posted : 26/11/2010 12:40 pm
Get a split pin instead FTW.
Posted : 26/11/2010 12:51 pm
Such a bad design - one of the reasons I got shot of my Oro's - I ended up thread-locking the bolts in 🙂
Posted : 26/11/2010 2:21 pm
