TAKE YOUR LANE- enf...
[Closed] TAKE YOUR LANE- enforcing the 3ft rule. Who's getting one?
16 Users
Not convinced this is a great idea..
[url= http://www.bikerumor.com/2015/11/11/pbe15-take-your-lane-makes-the-3-foot-rule-come-to-life-with-adjustable-safety-flag/ ]More here..[/url]
Posted : 12/11/2015 9:45 am
Not so good for pedestrians. 🙂
Posted : 12/11/2015 9:49 am
bindun
https://en.wikipedia.org/wiki/Bicycle_safety_wing
Posted : 12/11/2015 9:54 am
Posted : 12/11/2015 9:57 am
Mounts on the non-drive side
Hmmm. Not for the UK then!
Posted : 12/11/2015 10:06 am
"When asked how drivers react to the flag, David told us that the reaction around his home in Washington, DC has been great."
Yes, lots of waving, probably of the middle finger I would imagine.
What's needed is a battery-powered angle grinder on a pole. You could even wire it into one of those new Garmin radar things, so that when a car approaches, the pole comes down, the grinder starts up and you get to cycle in safety* as cars pass you wide enough.
Other than the fact you have a couple of kg of angle grinder lifting up and down, plus, it's an angle grinder.
Posted : 12/11/2015 10:07 am
That's going to ruin my Strava times.
Posted : 12/11/2015 10:10 am
Dumb idea because it'll prevent you moving to the middle of the road to avoid the door zone or being t-boned at junctions.
Posted : 12/11/2015 10:21 am
. Dumb idea because it'll prevent you moving to the middle of the road to avoid the door zone or being t-boned at junctions.
Why would it? If you're in the middle of the lane (rather than riding along the white line in the middle of the road) then you'd have three feet+ of space to your right (given then typical car lanes are 7ft+ wide) so there'd be room for the flag. And you arguably wouldn't have to move out so far because the flag would be making you more visible and preventing dodgy overtakes in the same way that taking primary does.
You wouldn't be able to filter or use a shared use path though.
And I agree that it's a dumb idea.
Posted : 12/11/2015 10:56 am
[quote=bails ]And I agree that it's a dumb idea.
Given you've just explained why it isn't, why do you still think it is?
Posted : 12/11/2015 12:18 pm
Why are the arrows pointing towards the bike? Shouldn't they point away from it as that's where you want the cars to go?
Posted : 12/11/2015 12:26 pm
Yeah, I was thinking that. I think they've just done a logo (see banner behind bike) without considering how it would work on the flag - though it would be fine here.
Posted : 12/11/2015 12:36 pm
I've always fancied a stick with a rubber version of, say this on the end:
Posted : 12/11/2015 12:41 pm
Three foot stick with a bottle of brake fluid at the end? Problem is you'd need to carry about fifty refills just for one of Sheffield's racing hills.
Posted : 12/11/2015 12:47 pm
 chip
A guy near me spins his seat post mounted mudguard 90 degrees to the right when riding on the road to encourage drivers to take a wider birth.
when/if I start commuting I'm definitely having 2 of these fitted along a length of plastiuc pipe that'll be mounted laterally behind my saddle, probably one each side of centre
I've got the bits, just need to bodge up a mounting mechanism
[img] https://lh3.googleusercontent.com/X3EvQursEqmEbqetRQ9eCluoP7o-epVPuJ8G2vH0FGrJ-3NDqoToSbgFqUUBNFNcm9q0qc6RIqcSEvmAj80GIw=s0 [/img]
Posted : 12/11/2015 12:49 pm
And think of the aerodynamics! And you're liable to get punched in the face by some arsehole who thinks you're out to block the road for no good reason.
How firmly attached is it? If I, when driving, give the required (in bits of the US) 3 feet of space when passing a cyclist do I now need to be 6 feet away from the cyclist because of the 3 ft flag? Or should I be 3 feet from the cyclist? In which case I'll be brushing the flag. If the cyclist wobbles and the flag gets snagged on my pickup, will that be enough to drag the cyclist over?
Posted : 12/11/2015 12:55 pm
[quote=bails ]You wouldn't be able to filter or use a shared use path though
How firmly attached is it?...
Ah, so the correct answer is "because I didn't read the information in the link"
Posted : 12/11/2015 4:17 pm
always find vehicles give me a very wide berth as I ride this around our area!
Posted : 12/11/2015 5:40 pm
 ji
Is that a Push me Pull you?
Posted : 12/11/2015 6:56 pm
