So I've tried turning the plastic screw underneath from 3 > 2 and it was only going half way then springing back to 3.
Tried a few times and pretty much ballsed up the screw head slot now.
Can't find the leaflet that came with the shifters.
Can anyone advise ta?
Posted : 23/08/2017 9:07 pm
You have to be in the middle or high setting for it to work as it just blocks the lower setting from what I remember.
Posted : 23/08/2017 9:10 pm
Or just adjust the stops on the front mech to stop you from physically being able to shift into the ring you've removed.
Posted : 23/08/2017 9:21 pm
Cheers somo I'll try that and then adjust the stops if not cheers Pot.
Posted : 23/08/2017 9:34 pm
User error, again. All sorted cheers somo.
Posted : 24/08/2017 12:06 pm
