Switching position ...
[Closed] Switching position of brake levers and shifters
[#1863656]
Currently my Rockhopper is set up as supplied with the shifters inside the brake levers.
I find that I have to stretch slightly to change gear and it struck me that I'd be more comfortable if I swapped them round.
Is there any reason they're set up that way? Will it all go [i]Horribly Wrong™[/i] and end in a pile of blood, bone and sinew? Or is it just a personal preference?
Posted : 05/08/2010 9:41 am
 br
The way you've got them means that you either need all four fingers on the brake or you'll trap the others if you only use 1/2 finger braking.
I run my brakes inboard of shifters - does though mean you need to 'lose' the shifter windows (not all shifters allow this, easily), and/or move them on the mounts (mine have 3 holes for 2 bolts).
Posted : 05/08/2010 9:47 am
Thanks b r. Just checked and I do no need to 'lose' the shifter windows (which I don't look at!). Is it possible to get covers for Deore shifters without the window?
Posted : 05/08/2010 5:19 pm
