Swap 9spd XT/XTR fo...
[Closed] Swap 9spd XT/XTR for 10spd XT?
I have the following 9spd components on my 2009 Anthem
XTR 970 shifters
XT 11-32 cassette
XTR chain
XT 770 triple crankset 24/32/42
XT 772 rear derailleur
XT 770 front derailleur
XT 785 disc brakes f/r
I have a box of XT 10 SPD that I took off my Orange 5 when I upgraded to M8000.
11x36 cassette, 22/32/42 chainset.
Personally I've found the XTR 970 shifters absolutely brilliant. Smooth and precise shifting.
I'm reluctant to change it just because of the shifters..but I'm getting a bit of what I can only assume is chain slip, peddle hard in the middle chainring and smallest sprocket and every now and then I get a click/clunk from the sprocket/chain/derailleur.
I think it's down to the rear derailleur being 7 years old.
So if I keep it, I'm looking at £40 for another rear derailleur. XTR 9 SPD chains are unavailable but assume £20 for a new chain. I have a spare XT cassette..
If I change all I need is a new front derailleur, £17.
What would the STW do?
Posted : 23/08/2016 12:57 pm
Anyone?
Posted : 23/08/2016 5:05 pm
is the jump not due to cassette wear? have you measured the chains to gauge the remaining life?
Your existing chainset sounds like 10 speed already as it's 24-32-42. 9 speed M770 XT was 22-32-44.
A 9 speed FD works fine with 10 speed but the cage is not quite optimal. There will normally be a "10" after the model number on the inside of the cage to designate 10 speed.
You dont need a 9 speed XTR chain. A KMC or other will do. I've got a collection of brand new KMC X9 chains here as I have now ditched 9 speed before using them.
Personally I would flog the lot and go 1x11, but as I have just built up a 29er with 3x10 to be my distance bike I understand why people still like 3x gearing (my other two "fun" bikes are now XT/XTR 1x11).
Posted : 23/08/2016 5:14 pm
Just checked the crankset..it is a 9spd M770 XT like I said but 22/32/44
I like the 3x9 on the anthem as it's my XC bike.. I use the 44 chainring a lot on the flats..lots of bridle ways and lanes.
The front derailleur on the anthem is top pull, and the XT 10 speed off the 5 is direct mount.
The chain isn't that old, but no I haven't measured it.. it only does that click/clink when it's on the 11T sprocket..
Posted : 23/08/2016 6:25 pm
sounds like the end stop might not be right or the 11T needs replacing (can buy them separate for a few £).
By keep the FD I mean 9 speed FD will work fine with a 10 speed shifter. Only thing that can be different is the cage shape for the 10 speed 24-32-42 rings compared to the 9 speed 22-32-44 but by the sounds of it you might have 10 speed rings on already.
Posted : 23/08/2016 6:32 pm
9 speed chainrings work fine with 10 speed and vice versa. Just don't mix on the same chainset without checking the shift ramps are in the right place.
Posted : 23/08/2016 6:33 pm
