Replaced the shock bushings on my Scout at the weekend an noticed that the pins that go through are a bit worn so thought I should get some spares. They are 21.8mm long and 12.7mm diameter, looks like it should be one of these but none are the right dimension:
[url= http://www.chainreactioncycles.com/rockshox-rear-shock-mount-hardware-1-2-x-1-2-/rp-prod54654?gs=1&gclid=Cj0KEQjw-Mm6BRDTpaLgj6K04KsBEiQA5f20EylrDZljc7nrLI7MhFfgXjPwX-4mkdVXPyLFPpQmqHEaAuRN8P8HAQ&gclsrc=aw.ds ]Rock Shox Mounting Hardware[/url]
Also any suggestions where to source a full set of good quality bearings?
I used a mix of CRC and enduro bearings for my smuggler.
The mount they use is a rockshox one:
https://www.amazon.co.uk/Rear-Shock-Mounting-Hardware-X1/dp/B001CK2J56?th=1&psc=1
Thanks, so do you think I need a 21.8 x6 or x8 version? Guess that refers to the inner bore which I didn't check 🙄
Not sure about good quality but any Transition dealer should be able to get you a full set of bearings for £30. I used Plush Hill in Church Stretton/Telford. I also had a set from mbbearings.co.uk which 'looked' exactly the same as the Transition ones.
As for bushes etc. I ended up getting some of the J-Tech HD Mounts and and some spare bushes.
