Superstar wheel hel...
Superstar wheel help, cassette issue
[#12725719]
Bought some Element something or other wheels a while back. Fitted new tyres etc yesterday. The freehub came with a spacer, I was fitting a SRAM 12 speed cassette onto the Shimano freehub and assumed I didn't need the spacer, however on fitting I needed to adjust stops on rear mech or it would shift off the bottom of smallest cog which I though a bit weird. Took it for a quick test ride and sure enough cassette rattled loose. So I presume I need the spacer, tried it despite me expecting it to mean the nut wouldn't grip it does, so is this usual? Am I doing it right? The old wheel (some planet x tank wheel that came with my Whippet) did not have a spacer
Posted : 16/02/2023 9:31 am
The freehub is road 11 speed standard, you need the spacer to use an MTB 11/12 speed HG cassette
Posted : 16/02/2023 9:36 am
Well that clears that up, thanks...what a ****ing pain in the arse all these standards are these days!!!
Just need to re adjust gears then!!
Posted : 16/02/2023 9:38 am
