Stupid Question - s...
[Closed] Stupid Question - single speed!!!
 Kal
I'm currently running my Scale 40 as a single speed using a tensioner and spacers on an xt hub! But I've just bought a Genesis IO frame and am not sure if I can use the wheel I have on the IO frame! This is the 1st time I've had a frame with a sliding dropout so any help would be much appreciated!!
Posted : 28/02/2009 10:46 pm
Yes, you can.
They're both be 135mm spaced.
Posted : 28/02/2009 10:54 pm
yeah, it'll be fine.
XT wheel will be just fine. It's easier to get chainline right with spacer kit on cassette wheel. If it's got XT q/r skewer it will probably hold in place fine. You might want to use a chaintug to help setting chain tension and will also make sure wheel can't come forward and/or one of those allen key replacements for q/r.
Posted : 28/02/2009 10:58 pm
it!will!be!fine!
Posted : 01/03/2009 1:38 am
